Previous in Forum: Hidden Talent   Next in Forum: Nickle Metal Hydride Batteries in CoolPix 950
Pyro Devices
04/23/2010 11:56 AM
What are pyro devices? I was reading up on IR sensors and the terms 'pyro output' and 'pyro devices' were used frequently.
Good Answers: 101
Re: Pyro Devices
04/23/2010 1:06 PM
Pyro means fire. Figure out the rest yourself.
Re: Pyro Devices
04/23/2010 3:01 PM
With all due respect Mr. Vader, may I refer you to this thread:
http://cr4.globalspec.com/thread/53647/Strange-Questions-Cryptic-Questions
Please dwell on the comments within. Thanks.
Good Answers: 101
Re: Pyro Devices
04/25/2010 11:41 AM
With all due respect Mr. Guest, may I refer you to this website:
http://www.google.com/
Please learn how to use it instead of depending on others to do things for you all the time. Thanks.
Re: Pyro Devices
04/23/2010 3:21 PM
Thanks Peter.
Good Answers: 119
Re: Pyro Devices
04/24/2010 12:25 AM
Designed LWIR intrusion detectors (PIR's) for almost 20 years and primarily used this type of infrared sensor:
http://www.nicera.co.jp/pro/ip/ip-01e.html#ip01
Also commonly referred to as a pyro sensor.
These are ideal for the longer 7-14 micron (human body heat) radiation. Pretty amazing what you can do with one of these, a $2 micro, and a little specialized signal processing. Of course the (far more expensive) FLIR imagers are a lot more fun to use.
Re: Pyro Devices
04/24/2010 5:47 PM
Thanks
Anonymous Poster (3); DVader1000 (2); mjb1962853 (1); peterg7lyq (1)
