Hello Everyone,
Last Thursday I noticed that we had no Domestic Hot Water running out of our faucets and showers. I'm trying to systematically determine why this is happening and also avoid getting hook-winked by the repair man if at all possible. I am not a mechanical or HVAC guy, just a Civil Engineer with only a basic understanding how this boiler operates, so please bear with me okay?
We have an oil-fired boiler Hydronic system that also provides us DHW. All of the cold water feed valves appear to be operating properly. I have even flushed the cold water service later and the cold water lines that provide fresh cold water to the boiler and the DHW coil.
Only a very small amount of hot water is making it to the faucet...mostly it's cold water. The boiler is providing heat to the radiators around the house with no problem whatsoever.
The past 3 or 4 years we've had problems with silica sand clogging up the faucets, shower heads, and especially the dishwasher, so i end up systematically going around the house removing aerators and filters off the fixtures and dishwater. It's a major pain in the butt having to do this. Mainly, the sand is angular silica sand, roughly 1 to 2 mm in size. Just large enough to get caught on fine screens and clog them really well after a few weeks to a month elapsed time.
At first I believed that or Culligan water softener w/ it's rock salt may have been the culprit, but I've since have changed my mind 6 months ago after changing the rock salt to salt pellets....the result was really no change in the clogging of our water fixtures and dishwasher. I have deducted that the sand is originating from either the municipal water main out in the street or our water service lateral (3/4" Type K copper line). I suspect the water main before the lateral; the water main is PVC pipe.
About 2 1/2 months ago, the village repaired a break on the water main at the other end of our street, some 1,200 feet away. We're on the opposite end, last house on the street before the main (reputedly) ties into another looped main along another street in our subdivision. Ever since that repair, our sand problem has gotten worse. Ditto with the pressure getting worse. I saw no evidence of the water dept. flushing the main after the 3 day repair job nor did I actually see them exercise the gate valve at our end of the street. I have called and complained about this situation to I am blue in the face----no satisfactory results so far nor rectification of the problems.
I had the boiler service guy here last Friday to look over the boiler and determine what needs to be done to rectify the no hot water situation. He didn't open up the boiler to inspect it. I did mention to him of the sand problems we've been encountering. He feels that the copper coil (for heating the water for making DHW) within the boiler may be clogged solid with the sand.....says the coil is roughly 3/4-inch diameter and 100 feet long.
Is this type of clogging possible? The coil has been ordered and the repair man is scheduled to arrive here tomorrow morning to start the work. I'm looking at a bill of at least $500 for starters and need to know if I'm being BS'ed and should watch him like a hawk during the dismantling of the boiler.
Also, I have a water filter unit to install on the 3/4" copper service lateral that will be installed tomorrow too. I didn't have a chance to install it before the big problems surfaced last week. I'm not sure about it's removal specs, but the box does mention removal of dirt..... no mention of how far down in size (micron) that it'd filter to. Would this cartridge been adequate or should I buy another one that I know 100% will work, say with particle removals down to 1 ~ 2 microns?
Any and all advice will be greatly appreciated! Have a great day!
