Previous in Forum: Welding with Smooth Internal Finish   Next in Forum: Stainless steel, hydrostatic test.
Standard Time of Manual Welding
05/18/2010 3:49 AM
Dear friends,
I need a manual, norms, instructions for estimating of standard time for manual MIG and TIG welding. We need to estimate normal production rate.
Regards,
Pathfinder Tags: Welding
Re: Standard Time of Manual Welding
05/19/2010 11:09 AM
I think you need to provide a bit more information about the type of materials you will be welding (aluminum, vs Stainless Steel) , what the shape(s) are (pipe vs plates etc.) , what the ratings on the welding machines are. etc.
Good Answers: 18
05/19/2010 3:02 PM
Standard time for semi-automatic MIG and manual TIG depends (to a large an extent)upon following factors:
1. Size of the filler wire say -- 0.80, 0.90, 1.00, 1.20.(MIG) & 1.60 to 2.40 mm in TIG,
2. Butt or Fillet joints,
3. Positions of welding,
4. Base metal type and thickness,
5. Type of metal transfer in MIG Process etc.
With such above variables , you may not get accurate estimation.
As for norms, instructions etc., please let us know what is your actual requirement.
Sridhar.
What we have done for ourselves alone dies with us: while what we have done for other and the society remains and is immortal.
05/18/2013 3:02 AM
hi shridhar....
Hws u....Im studying on the same welding time . We can surely share the data , plz contact.
CR4 admin - email address removed:
From the CR4 Rules: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers and email addresses posted in threads or comments. You can share this information via the CR4 internal messaging system.
05/19/2010 10:10 PM
Who manufactured your welding equipment? Perhaps they have or can help you access that information .
05/20/2010 3:26 AM
Thanks to everybody.
We can estimate welding velocity, the problem is auxiliary time (set-up time and manipulation time) estimaton.
06/20/2023 9:10 AM
The <...we...> needs to carry out a local assessment. It's not something an anonymous international Engineering forum can help with, really.
Register to Reply 6 comments
ainul.inamdar (1); Anonymous Poster (1); Efim (1); PWSlack (1); SRIDHAR (1); Tom_Consulting (1)
