Previous in Forum: Solar Water Heating Idea   Next in Forum: How Do I Turn Over a Basket at the Top of a 20' Drop?
32 comments
Challenge to Stop the BP Gulf Oil Spill
05/26/2010 8:03 AM
To all CR4 community members this is a challenge for everyone associated with or concerned about the BP Gulf oil debacle.
BP-Trans-Ocean and Government agencies are failing to listen and we need to push them into doing the right thing.
Below is what has been posted on the White House Linkedin engineering site and we the CR4 community need to be part of.
This has been posted on the White House Linkedin web site as a discussion forum and needs to be a round-robin effort by all interested in doing something which BP/Trans-Ocean to date seem not able too.
Out-reach too ALL engineering communities and professionals for solutions for the BP Gulf problems, submitted on their web site form or via emails
Many people have submitted good solid and workable solutions to BP via their WEB Site form and have not received responses, even to emails.
Suggest the President and Secretary Salazar have BP/Trans-Ocean at their own expenses organize a full 3 day meeting in DC of all those submissions for a Brain Storming Session, for a set of solutions...lets request next week....allow all to attend as an open forum and BP pays for everyone to attend (make form available on all Linkedin, GlobalSpec CR4 and Incentives .com websites and Universities.
Allow all who sent in ideas and then some more (BP has the list of submitters give too White House...keeps it transparent).
May 25th 2010 posting
Geoff Daly NH
Geoff Daly Nashua NH
Re: Challenge to stop the BP Gulf oil spill
05/26/2010 9:12 AM
I appreciate the frustrations of those directly impacted by this spill and the eagerness of good people to offer any help they can, including brainstorming ideas to put an end to this crisis.
However you must realize that there have no doubt been many thousands (perhaps tens of thousands?) suggestions submitted to BP et al. And while each must seem "good solid and workable" by their generous submittors, the vast majority simply are not suitable due to unrealized technical, logistical or time limitations. And I imagine BP doesn't have the resources to respond to these, nor to investigate the feasibilty of some of the more exotic ideas.
While it would make for an excellent story if the solution to the problem were dreamed up by someone with no experience in the field, for the time being it seems more prudent to confine the brainstorming to industry insiders. Which I assume BP has been doing, although it would be nice to get some confirmation on that.
Re: Challenge to Stop the BP Gulf Oil Spill
05/26/2010 10:02 AM
Capture a large percentage of the oil in a fabric sphere. Just like a water balloon. A 100' diameter sphere can hold almost 4 million gallons. Let the fabric be resistant to oil transmission. Fill one, follow it with bouys, but let it drift. Adjust the bouancy so that the shere is below the water surface. Provide a pressure relief flap to let expanding gas escape. track it and suck the oil out at resonable depths and at the conveience of available support. Fill one, then fill another. 100' too big? Use a 50' diameter balloon to hold almost half a million gallons.
I give this idea freely to anyone with a big ship as long as it is called "BillyBallz".
05/26/2010 11:00 AM
Sorry, friend! I already have patented the idea. See post # 37 at This location
Bridge rule #1: Nobody is as good as he thinks about himself nor as dumb, as his partner thinks...
05/26/2010 11:12 AM
Sorry, your Patent was denied due to insufficient definition. ;~)
05/26/2010 12:13 PM
Indel and Chris288g,
Several of the above discussions/postings andon the other thread for the use of sound; has been actually reviewed by BP but they do not understand the principle let alone the concepts or they do not want too, "Ostrich in the sand mentality".
What they have considered, submitted by me on April 25th, and after much prodding and pressure from several congress people is this:
Build a 250 ft diameter inverted flexible funnel secured to the sea bottom via 1" steel hawsers and weights attached to the fabricated steel ring of the funnel...around 50 ft above the BOP.
The funnel is 150 ft tall and is secured to a 20 ft diameter steel chimney section 40 ft tall at the top.
Attached to this steel chimney section is a continuous flexible tube all the way to the surface, where it bells out to around 100 ft diameter and attached to a large inflated rubber ring (10 ft daimeter tubing ring).
All attached to a series of huge river barges (100 ft long 15 ft wide and 22 ft deep) via a series of steel hawsers runing down the flexible chimney walls and the funnel for added strength.....sketch drawings have been sent and reviewed.
The leaking oil is then captured in the funnel and allowed to rise up and into the chimney...is captured and held by the flex tubing/funnel.
Take off nozzles 12" to 24" diameter can be placed at underwater points to capture either just the gas or a combination of all coming up. Attached to the surface area woruld be a whole series of suction pipes to remove anything coming up and transfer to tankers. A water spray would be applied over the whole area to suppress the gas from igniting etc in the take off ring area and the surrounding ocean
These tankers would then take the water/oil/gas to a terminal for separation, which they do now anyway.
The material proposed for the Flexible funnel and Chimney is made by Chemfab of very high strength fabric and coated in TEFLON....Denver and Riyadh airport roofs and the Millenium Dome in the UK are made of this material...is extrmely tough and can take upto 950 Lb/In tensile pressure and works down below -30C.
The funnel would not see any real pressure applied other than some wave forces and bumping around if the water to Oil ratio changed the flow density.
Professor Eric Adams of MIT had mentioned a similar idea in his interview last week in the Huffington Post...he has reviewd the sketches submitted and agreed would work and should have been done weeks ago; Professor Ian MacDonald of Fl state U also sees this a a good method...just need BP to build and not delay any further.
Anyone have any other ideas?..The Linkedin and Innocentive.com group are getting good ideas as well.
Also need away to capture the oil now in the ocean....Supertankers? .....and in the Wetlands-Marshes.
Geoff NH
Chris, maybe modify your drawing to the concept above...good concept and first response on the other thread?
Good Answers: 130
05/27/2010 12:06 AM
Geoff;
From what you have 'borrowed', you are way behind, or scratching to understand, dvm's concept.
I am glad dvm used a child like sketch, and the physics, and/or real hardware configuration appropriate, was not illuminated in the thread.
Doubly disappointing, as such as this "challenge", simply diverts effort and support for a quick and viable fully encompassing solution of all emanating products, and makes it look as if dvm's simpler, practical and science correct idea is not "the right answer".
Why do you not get behind the 'other person's idea' and use what ever influence or skills you may have, to unselfishly promote them and their efforts, like the others in the know, who have gone silent or private so as to not "give his concept away", or muddy the efforts?.
05/27/2010 5:55 AM
BP are a large commercial organisation that has made money for most of the last century. They are currently losing money in the hundreds of millions of dollars per day in lost oil leaking out.
Plus untold billions in clean up costs
Do you really imagine they are sitting on their collective asses while the company potentially goes bust.
The problem with the open forum suggestions is that those submitted by people that read here are likely to have merit, they may not be the whole solution but they are likely to provide inspiration and enlightenment. However it is likely that CR4 subscribers provide no more than 1-2% of the ideas which I would guess are in the 100,000s.
Unfortunately most of the ideas are submitted by dreamers with no concept of reality and sifting through the forums for the worthwhile nuggets is panning for gold and so there is no chance of BP really being able to engage in meaningful dialogue with those like our post leader here with something worthwhile to contribute.
Whilst a roundtable head banging idea in washington sounds great you know it will be dominated by loud mouth politicians who last took a science or engineering class in high school and are grandstanding for the voters who suggest we train shoals of fish to falp their tails in synchronous work to push the oil into a ball!
05/27/2010 8:50 AM
They have a cap to monetary liability that they already know will exceed the cost. They want to recover their investment...the leak goes on. Stick a bilge plug in the thing already.
05/27/2010 8:52 AM
The Federal Goverment just gave them permission to try top kill...who's at fault if it turns bad?
05/27/2010 9:39 AM
Simonsd,
your commnets are valid and make a certain amount of sense. But consider this aspect, if no one ever challenges the establishmnet or questions authority then we will see more of George Orewells 1984 on our lives.
You like me hail form the UK. Look around at big brother camera's, government interference with civil servants obstructions, an out of touch political system...voted in by the people.
CR4 may not always seem an appropriate forum sometimes, except the thread on Haiti and use of shipping containers has caught the attention of many agencies, so we have an effect. Even the UN is now after 6 years of studiying emergency shelters ideas at great expense giving there use credence.
So perserverance is in order as some one somewhere will see that no only CR4 but Linkedin and Innocentive.com are viable sources for solutions. These communities have a varied range of profesional disciplines answering requests for solutions, eg, can anyone give any idea of the long term effects of Corexit on the Marine/wildlife in the Gulf area..is banned in the UK where BP is HQ'd
Your point is well taken that some political ranting by politicians will take place along with the paid lobbyists. But again let them!....if T"Boone" Pickens was to chair the meeting then let them try and force there will on the best minds who could attend...such luminaries as Porfessors Eric Adams of MIT, Ian MacDonald of the U of Fl State, companies like Saint-Gobain Corp, AB Technologies, B&P centrifuges, Eimco etc.
These people and companies could not be ignored for there ideas, technology and all within CR4, Linkedin and Innocentive.com communities....if so then god help us all going forward.
Just remember BP was involved in a Norwegian Sea deep water spill test in 1997 and TransOcean before its name change had a similar failure in the Gulf in 1979 in only 200 feet of water....tried same techiniques as today, when will any one learn or remember from past tests/errors/disasters.
So we must keep trying to put ideas together, yes some will be off the wall. But that's what the thread is for BRIAN STORMING..others will moderate and good solutions arrived at.
One guest asked about the "TOP KILL"...go to the live feed (which by the way is some times being loop feed by BP...not fully live). So after nearly 24 hours as of 2:30 PM EST this afernoon BP say they will know if it is working. Well from all the video so far and from some associates of mine in the industry...seems more mud etc is coming out than staying in and there are now several more fissures appearing away from the BOP (not always viewable except at the energy departments feed in DC and they become "dark" every now and then?).
By perservering we can have an affect on decisions. Maybe the other thread should be joined with this one by a link.....Chris288g can we get Garthh to see if he can do this?
05/27/2010 10:10 AM
I think sometimes we just need to SIMPLIFY things and take them for what they are! No caped crusaders! Just stick something in the darn hole! I can thing of many things...save the mud, everyones slinging too much of it as it is!
Good Answers: 204
05/27/2010 6:13 PM
which link? there are so many now....
05/27/2010 10:56 PM
Chris,
is the "stopping oil spill with sound" thread..your post 24 and 31 showing your ballon lever set up...quite creative using mechanical advantage and the soft mud surrounding the BOP site...which by the way sits in a canyon type gully if you look at the robo-cam views.
May need to be big...around 60 to 100+ feet plus diameter and as you said with some valves to be open to get dome in place then settled before closing.
Geoff NH
Good Answers: 204
05/28/2010 12:05 PM
Hi Geoff,
I think we all realize there is no easy fix here. I'm slowly studying that Triz methodology that Garthh pointed us to (elsewhere) for speeding inventions.
A great deal of that is to narrow the field of search to the set of solutions that correspond to the clarified design parameters. here is a preliminary setup
INPUT PARAMETERS
  • 18000 foot well to active oil reservoir
  • multiple leaks from failed equipment/pipe
  • fractured rock formation
  • 5000 feet under water (2200 psi)
  • high (unknown?) wellbore pressure
  • nitrates (ice) form upon depressurization
  • casing and bop's in place, but partially blocked.
  • wreckage/equipment surrounding well
  • deep mud surrounding well (LS)
  • thousands of barrels per day leakage (volume unknown)
  • casing, pipe, concrete, packers remain in wellbore.
SOLUTION SET
Geological Solutions
(any solution which fosters an adjustment to the intervening 18000 feet of rock, thereby stopping the flow of oil)
(ie. explosives)
New Equipment Mechanical Solutions
(any solution where new equipment is designed manufactured, and installed, and can successfully stop or cleanly divert the oil flow)
(ie. caps, tubes, suction pumping at source, etc)
Existing Equipment Solutions
(any solution where existing equipment is used, repaired, or activated, to effectively stop or cleanly divert the flow of oil)
(ie. top kill, packers, concrete filled drillpipe, etc)
New Equipment Non-Mechanical Solutions
(any solution where non-mechanical methods are used to stop or cleanly divert the flow of oil)
(ie. stopping oil flow with sound)
Oil Negation Solutions
(any solution where the effects of oil entering the environment is negated in some respect)
(ie. dispersants, detergents)
Strategic Containment Solutions
(any solution where the effects of oil entering the environment is prevented from acting upon that environment by physical barriers)
(ie. oil booms)
If I've missed anything.... jump in.
ps. Geoff, it would appear that some are misreading your intentions with this thread. Perhaps some clarification. I know you are an excellent organizer, (and friend) and are trying to move this issue to a higher level of organization, if possible, and to once again, ensure that engineering voices from CR4 are being heard by decision makers. I applaud that, but I don't think everyone perceives this the same way. I'm a drafter and inventor, but not a political bone in my body... so I appreciate when people like you to take note of my ideas and present them to others who can do something helpful with them. I'm usually pretty humble about my ideas, and if I've put them on the internet, they are public domain automatically.
Good Answers: 141
05/28/2010 2:26 PM
a GA
Plenty of room here
06/11/2010 2:54 AM
Could a pipe of smaller diameter than the well casing be inserted into the casing? If such a pipe had "dogs" or "cams" on the outside that as the pipe tried to pull out the cams would bind against the sidewalls of the existing casing?
If this could be done, having side pipes on the inserted pipe to stabilize it over the casing with trip valves to shut these off once the new pipe was inserted, Then a shutoff valve or piping to divert flow to the surface could be used to capture the majority of the oil...Some would still leak by between the new "cammed" insert and the existing well casing but if say the casing was 36 inches and the insert was 34 inches (sizes are my guess but you get the idea of scale here.) This would cut the area of escaping oil and gas to about 10 percent of the original casing. I can't find any specifics on the well casing or I might suggest -if pipe is sticking up high enough - attaching a split flange below the leak and welding it on roboticly and then sliding a flanged section with valve over the well and bolting it to the new flange then closing the valve...I just don't have enough information to make a good judgment on these things. Thanks for what you are trying to accomplish.
If no casing exists then longer dogs to dig into the sidewalls of the ocean bedrock and deeper insertion would be required...same idea though.
Hobbies - CNC - New Member Engineering Fields - Mechanical Engineering - New Member
05/27/2010 11:45 AM
seems like a larger hole in the first thing they put down there, the dome stucture, would allow the gas crystals to float up and allow the oil to come to the surface for collection. maybe a rod down the center of the collection pipe could be used in the original dome to move the crystals out of the way to allow the oil to get up the tube.
other wise the flexible tube of a very large diameter, that has been posted in cr4, would seem to be doable, however it may take a very long time to fabricate.
good luck everbody......
05/27/2010 11:50 AM
The methane forms the hydrate as it comes up out of the earth - should plug up most anything shortly in the event the temperature/pressure is right for it. Also remember this is happening one mile down - not exactly like cleaning the sink drain.
05/27/2010 1:22 PM
Is it possible that a decisive leader, could have implemented the removal of the casing to surface pipe entirely, and without hesitation, there by reinstalling it...reduced the now unsurmountable, unimaginable leak we have on our hands? Anyone have a formula for that? Is it possible we could have sacrificed little to save a lot? We used to look ahead, now we only look behind. If our brain with 2 hemispheres is capable of only thinking of two things at once, one thought being political, and the other finger pointing/liability, who's thinking about the spill? If everyone agrees..then there is only one brain doing the thinking...
05/27/2010 2:03 PM
Unfortunately there is no Red Adair of plugging leaks in the ocean floor it seems. Several groups do fantastic at fires - No big companies but small groups that step in and take over. One big problem with leaks like in the Gulf is the immense cost of the equipment involved - robotic subs of the size they have - the pumping equipment etc.
05/27/2010 3:51 PM
No, just my point! Everyone looks back,that is recall from experience. Every time you remember an event it changes, because of new experiences. The memory is different every time you recall it, the new information reacts with the initial memory. THERE is nothing like this in my memory. There is no information relative to this situation, period. It demands forward thinking and decisiveness. Someone needs to take charge, and implement a solution based on their gut. The right thing to do, we all depend on it. I am not an environmentalist, I am a conservative. The difference is , an environmentalist wants to protect it so no one can use it, a conservationist wants to protect it so everyone can use it.
Good Answers: 80
05/27/2010 3:50 PM
The original funnel was a good idea. It is just missing some heat!
Supply limited oxygen down at the leak and burn some of the gas as it rises through the funnel. The limited oxygen supply will control the combustion. The increase in temperature produced should be enough to prevent freezing.
05/27/2010 7:04 PM
Wrench,
if you read my posting above this is exactly what has been proposed a large inverted funnel-Chimney..... all made of the same TEFLON coated fabricate material supplied by ChemFab for the Denver and Riyadh airports and the Millneium Dome in the UK.
Was sent to BP and TransOcean on April 25th...they never responded till yesterday, they are now panicking after all this time...could have had it built and in place.
ChemFab can and has the production capability to make all material in 8 days based on a 24/7 production run to make a fully finished funnel-chimney.
So is more than doable as reviewed by a peer group including several Professors from MIT, U of Fl state. ...along with a few other solutions. Now they are looking to get something built.
Geoff NH
05/27/2010 6:03 PM
Thinking some more about my previous post. How about an auger in the pipe at the top of the dome structure to mechanically lift the gas crystals to be lifted up to a lower pressure- higher temperature area in the pipe. Would that stop the blockage in the pipe.??? Of coarse that would require another drill rig to be placed over the well to provide the rotation equipment for the auger.....?????
05/27/2010 6:10 PM
What is the chemical reaction with the "hydrates" and the gas-oil in the well that is causing the plugging of the original dome system? Just trying to understand why the dome structure did not work. It seems that physics wise, it should have worked......
Good Answers: 141
05/28/2010 2:23 AM
This problem is definitely not understood by the designers of the dome and the top hat. And also (not) by 16995 of the 17000 of the providers yesterday.
This is a domain where physics only do not provide the answer.
A multi discipline approach hardly found in classic engineering has the fix to it.
BP never encountered this problem in pumping oil out of a well, or like this case, with a well under high pressure.
Few people know exactly the underlaying dynamics and how to deal with it. We'll come back on this later. Bringing the oil up is a dynamic process, seen the circumstances very unusual and not experienced before.
Why big, open companies consult external advisers? When I have questions, I listen to good advice. You need no oil man to solve this problem.
Plenty of room here
05/27/2010 9:36 PM
Are there not enough posts about the oil spill?
From all the threads this smells like the most opportune one. What is the issue?
Do you need to show how you can make the difference?
Where is your idea?
You didn't even do your home work well and read everything or made a list of possible solutions.
I am posting here and have not one good answer, but that is because I work here to help this forum contribute and does something for the people.
And when I do not know what to answer, I simply read and do not contaminate.
There is already far too much confusion and chaos. 20.000 application forms for "the solutions" make it even impossible to spend time for the decision makers to even read them.
Evaluation is totally out of the picture.
You are 37 days too late. I have read some good posts here and have supported these. You can go 2 directions, and I call yours Backwards. Of course you have the right to disagree, but your intro does not convince me.
05/28/2010 12:39 AM
@cherryvan - İt is apparent that many of the posters have not maintained a close watch on what has or is happening on site. There are blogs out there (http://bittooth.blogspot.com/) that are the view from someones eye that understands what is happening. Many of the posts here are like you receive from the office when you are in the field with a problem!
05/28/2010 2:37 AM
Russ123, I understand you completely. The engagement to the topic of some posters has been immense, nights without sleep, telephones, travel, tests in some cases and it is hard to endure that in this century of communication, just a fair communication seems impossible, with catastrophic consequences every day further.
Search this forum and type words like - oil spill - big spill - BP - gulf - disaster and you will be surprised what has been produced. All the good intentions end up like 20.000 people trying to call. respectfully, take care.
05/28/2010 8:39 AM
Finally! Yes backwards!
06/01/2010 3:01 PM
Maybe what happened in the first try to cap and funnel oil up is a clue to what might work. Use some refrigeration or supercooling system with liquid Nitrogen to stop it before a quickdrying cement cap. If the pipe could be super cooled before they cut it (like plumbers freeze pipes) might help what they are planning on doing now. Maybe none of this is practical 1 mile down but it is already pretty cold down there which might help.
A second thought is to insert an expanding device which you would start to open up before the pressure would do the rest and take over locking it in the hole by expanding it further. Probably simpler said than done!
I have dial-up (dish too expensive here) so I haven't had time to find all postings on this so these may have been suggested elsewhere.
Thanks for allowing me to post!
06/09/2010 5:51 PM
"A second thought is to insert an expanding device which you would start to open up before the pressure would do the rest and take over locking it in the hole by expanding it further. Probably simpler said than done!"
I'd been thinking on similar lines. Plumbers now often use push-fit pipe connectors: these employ a combination of O-rings for sealing, and backwards-facing metal teeth which "grab" and hold the pipe. The point is that the greater the water pressure, the harder the teeth grip the pipe. Surely BP could adapt this idea.
Register to Reply 32 comments
34point5 (1); Anonymous Poster (9); cherryvan (2); chrisg288 (2); Dave UAN (1); dvmdsc (2); Geoff Daly (4); indel (1); marcot (1); Natfuelbill (2); russ123 (3); simonsd (1); the wrench (3)
