Hello Cr4ites,
I am a relatively new designer. Our company, which makes electrical connectors, has been doing reverse engineering for ages now. Generally ppl use vernier calipers and intuition to measure the modeling dimensions. Sometimes, the optical projector is used for intricate/critical profiles. But it can be used only for external profiles. Internal profiles are generally measured using calipers.
Yet, we have errors. I have started verifying dimensions of all reverse engineered drawings. But are there any methods/instruments by which better accuracy can be achieved in reverse engineering? Or does the designer's skill play a major role in number/magnitude of errors? Or does this always happen in reverse engineering and we have to contend with it?
This issue is not exactly critical at out place but it is irritating with the no. of changes in tooling and eventually product delay/underperformance. Any advice will be appreciated.
Cheers
Talaus
