Previous in Forum: Polyimide Wire Enamel and Coating   Next in Forum: Water Tube Boiler and its Accessories
Acid Recovery of Spent Pickle Liquor
03/01/2007 8:40 AM
I am trying to recover or reuse the spent acid used in pickling of steel. But the available methods are either too complex or too expensive. One of the easier method is by diffusion dialysis, but that also requires special type of semipermeable membrane that can permeate acid but does not allow ferrous and other impurities to pass through. But such membrane are not available commercially in loose. Please suggest me any method to easily regenerate sulphuric acid, Nitric acid or Hydroflouric acid from its impurities after the pickling process for small scale. Or please tell me where I can get such membrane in and around Delhi or give me any link as to how to make such a membrane easily.
Pathfinder Tags: acid recovery steel
Re: Acid Recovery of Spent Pickle Liquor
03/02/2007 11:55 PM
I use a vacuum pump to remove the water in the acid. Whatever was held in suspension by the acid will fall out as a sludge or formed material. Then pour off the acid. I have used this technique for acid used in mining, electronic circuit processing and in various lab apps. Watch your vac discharge Ph to know when to quit.
Good Answers: 243
03/03/2007 12:12 AM
Why????Do you believe in perpetual chemical activity?
Once the % of iron gets above say 7%, you can add fresh acid all day to the bath and it won't remove scale, because the high iron content will prevent it from working. Proper question would be what salts can i generate from this and how else can i use acid to neutralize alkaline waste somewhere else and solve two problems at once. Actually It may be 8%, I'm in Orlando at a conference and I dont have my notes and its been 16 years since we ran pickle lines - we replaced them with shot blasters.
Good luck.
milo
Register to Reply 2 comments
