Previous in Forum: Reinforcement Pad   Next in Forum: Pressure Test
Pressure Test
07/29/2010 2:34 AM
How do i know what pressure to test a u-bend for different thicknesses?
Re: Pressure Test
07/29/2010 3:02 AM
Do a hypothetical slice through the bend in various planes and carry out a force-balance calculation on it for each slice.
Re: Pressure Test
07/29/2010 6:31 AM
"Simples! ξ"
Re: Pressure Test
07/29/2010 9:14 AM
If I have a 19.2mm U-Bend in ASTM A351 HK40 Material, to what hydrostatic pressure must I test it?
Re: Pressure Test
07/29/2010 11:03 PM
It would depend on the wall thickness.
Re: Pressure Test
07/30/2010 12:49 AM
The wall thickness is 19.2 mm.
Re: Pressure Test
07/30/2010 1:09 AM
In that case, then it depends on the diameter of the tube from which the U-bend is formed. It may also depend on the center-line radius of the bend.
Not only that, your OP mentions different thicknesses.
Re: Pressure Test
08/02/2010 4:12 AM
The ID of the bend is 140mm and the minimum wall thickness is 19.2mm.
Joos (3); PWSlack (2); Tornado (2)
