Previous in Forum: automated chest compressor system   Next in Forum: Phorphorous Materials
31 comments
Coal-Powered Lawn Tractor
08/05/2010 10:55 PM
Whilst mowing the grass on my 42-in., gasoline-powered Cub Cadet tractor, I got to wondering: Why couldn't a lawn tractor be battery-powered? Take out that big 18hp motor, tranmission, drive train and complicatred belt drive system and replace them with two electric motors--one to propel the mower and one to run the blades. Install 6-8 12V car batteries where the engine used ro be. Use a standard battery charger to charge them up over a week's time between mows. Would that be enough to mow a one-acre lawn?
Life is like a sewer. What you get out of it depends on what you put into it.--Tom Lehrer
Re: How hard would it be to build a coal-powered lawn tractor?
08/05/2010 11:09 PM
So wheres the coal come in? Unless you are talking about the power plant.
If so then some of us would have hydro electric powered lawn mowers, wind powered lawn mowers, or maybe even nuclear powered lawn mowers?
Oh ya, you know that wild little boy en each of us just perks up at the thought of engineering a nuclear powered riding lawn mower.
Canada - Member - New Member
08/09/2010 1:17 AM
"So wheres the coal come in?"
Maybe the 'OP' meant to say "Kohler"-powered lawn tractor.
Have a Happy! ;-)
08/09/2010 5:17 PM
The 'coal' is from 'coal fired power plants'.
Coal is the most prevalent way to generate electricity in the USA, far exceeding all other power sources. So if you plug in and use electricity, you are indirectly using coal in a very inefficient manner (considering losses in the power production, transmission, and in final use).
Natural gas is a little cleaner. Hydro, solar, and wind are 'best' from an environmental perspective. Nuclear is dirty in a different way. Politics and public opinion change from time to time, but facts based on science (not 'pop-science') change very slowly.
Good Answers: 141
08/05/2010 11:14 PM
This one and a good exercise does it on battery. One spare bettery needed.
The company that builds these for Toro could also go tractor.
[p] The photo didn't make it through here, but the link works with me.
Toro 20360 e-Cycler 20-Inch 36-Volt Cordless Electric Lawn Mower
Buy new: $399.00[p][p]Bigger motor, bigger battery packs on a 42" frame.
Plenty of room here
Good Answers: 1693
Re: Coal-Powered Lawn Tractor
08/05/2010 11:19 PM
6-8 12 volt batteries weigh about 240+ pounds, and occupy more space than the gas engine and transmission.
Good Answers: 141
08/06/2010 12:25 AM
He could also work with less batteries and have a few pit stops with combined beer drinking? I work here (in a different application) with 2 X 12 Volts batteries and a motor from a pallet transporter. He will of course have more weight. I still prefer gas anyway. Cheers. D.
Plenty of room here
08/09/2010 4:31 PM
How about a battery trailer (cables to the mower motors)?
08/05/2010 11:36 PM
Seen similar to the TORO sold in Aus, but here they offer solar panel included instead of charger transformer.
From memory cheaper than the petrol mower, but limited to around 2 hours work per day. (Which is one reason why I think the next mower will be that type).
Full re-charge time is claimed to be around 10 hours, so I could get 2 hours on Saturday, have a few brews with the BBQ lunch, then another couple of hours mwoing on Sunday before the afternoon roast and wine.
I'm getting older and this would be one way to make sure I don't overdoo it.
08/05/2010 11:53 PM
Here in the USA, most of our electric power comes from coal, so a battery-powered lawn mower is actually a coal-powered mower (as will all the electric cars in our future).
No one addressed the technical question of: Can it be done? If Toro sells one in Australia, it must be possible. It takes me two hours to mow my one-acre lawn with the Cub Cadet, so that would work for me.
08/06/2010 10:31 PM
actually, you could power the gasoline engine mower from coal, woodchips or about any dry bio-material, During ww2, volkswagon built gassifier systems to power some of their cars. Search woodgas, or join yahoos woodgas group. There are several people now running their vehicles and generators from wood waste in the group on a daily basis. Fema even has plans posted for emergency woodgas systems, although the fema version will screw up your engine in a few hours of run tim, go figure,lol. Yahoo woodgas members have made several cross country trips, just on wood fuel.
"god gave us fuel, greed gave us gas"
Good Answers: 213
08/06/2010 11:04 PM
To get an idea of using an electric drive motor, have a look at electric golf carts. The ones I am familiar with (EZ-GO brand) use six each 6 V batteries (sorry, don't have the AH ratings on these right now- check the EZ-GO website). Assuming you are not mowing a mountainside, I should think you could get a lot more than 2 hours out of this sort of setup. Adding a mower to the underside of one of these may be possible, or you might want to think in terms of a towed mower with it's own motor/battery set...I am not sure how difficult it would be to design a power take-off from the drive axle to drive the mower head on a golf cart, but it may be possible. I am also not sure how much power you need to drive the actual mower mechanism- that would require some study.
08/07/2010 11:37 PM
Yes it can be done, and has been done many times. Works fine. Look here for some ideas. On the second page of these listings, there is a GE E20, which was a production tractor that provided 2.5 to 3 hours mowing time.
Si hoc signum legere potes, operis boni in rebus Latinis alacribus et fructuosis potiri potes!
Good Answers: 49
08/07/2010 12:00 AM
There are several deep-cycle battery-powered multi-terrain vehicles out there. Get one of those and rig up a tri-pod hitch for 3 20-inch wide "push" mowers- driven by the wheels and gears- no motor- with an overlapping cut for about 48-54" wide cut. You will get the job done quicker, quieter and a lot more comfortably than straddling your Cadet.
Then, when you are done mowing the lawn, you can unhitch the mowers and use the vehicle as it was designed- cruising down the street (or sidewalk) to the local pub-malt shop-Dairy Queen (whatever suits your needs).
NO MATTER HOW WELL YOU HAVE DONE SO FAR, ALWAYS TRY TO BE BETTER TOMORROW.
08/07/2010 2:15 AM
Why mow and burn coal/electricity?
Let it grow and keep a few goats or sheep or something, the milk is good from goats and the meat is great from both. With 1 acre, you should be able to keep around 6 goats, well tethered of course.
Or buy a scythe and get fit......and a push mower for the fancy bits!!!
YSou will end up as fit as a flea and save money!!
08/07/2010 10:49 AM
It would be possible to rig a solar charging station, a couple of solar modules on the roof of a storage shed and a simple charge controller. Just plug in the DC charging lines to the batteries whenever needed. If it is rigged right, with a proper charge controller, should be able to leave it plugged in all the time when not in use. I would suggest not even going to AC, and do it all DC. Running DC wires very far do have losses, needing bigger wire or doing the conversion to AC.
I have wondered how much energy it takes to build a solar module, so what the ROI would be on them.
Good Answers: 80
08/07/2010 3:38 PM
GA Andy. At least for warm areas.
The problem is that in the north, the grass cannot be used to feed the goats all year round. You still need to cut grass in the summer and store it for winter feeding of your goat. The solution might be to eat it in the fall and buy a new one in the spring like the farmers used to do.
08/07/2010 4:39 PM
True!!
Good Answers: 11
08/07/2010 7:46 AM
Been there did that. We built one using a power wheelchair as the base. New, it would have been about $5,000.00, but there's a slew of good, used ones out there for about $1,000. In this case, we found a Pride 1170XL HD only 6 months old for $800. It's a 500 pound capacity chair powered by 2, group 24 batteries that were rated at 78AH each. This gave the chair, as-is a range of about 12 miles at about 5 mph with rider. Then we thru-bolted on tractor tires to the existing hubs, built the cutter deck and mounted a pair of gearless-brushless motors under it that we picked up new for about $150 each. A separate controller for the G-B motors was needed, and a converter to take the 24vdc from the batteries down to 12vdc for the GB motors; that was a kit for about $125.00. Not including labor and beer, the total was under $3,000 after fabricating costs got rolled into it. It mows 2 acres in about 3 hours or so, or right around a 6-pack and still has enough legs for a front and back yard. With the 2-motor drive set-up and joystick controlled steering, you can manicure around a maze of kid structures with ease. It's cutting about a 48" path too. A new John Deere with that sort of capacity will run $4,000 on up. And they only come in green. Recharge is about 6 hours.
08/07/2010 8:19 AM
I think what you are describing was built by GE in the 70's. It was called the Elec-Track tractor with a mower in front. Check out elec-trak.com We sold them and they were popular with the people that wanted to cut the grass early in the monrning when everyone else was sleeping.
Anything can be made, sometimes at great expense, resulting in greater satisfaction, :)
Good Answers: 29
08/17/2010 1:03 PM
John Deere did it as well with their model 90.
http://tinyurl.com/28ap9co
Hustler currently makes one they call "Zeon"
http://tinyurl.com/2fscr42
I work with a older fella who owned an Electrack. His was struck by lightning. He says his insurance agent nearly sued him for fraud! Didn't believe there was such a thing.
08/07/2010 8:54 AM
Slow Old Poop,
I have several years experience with a second hand 42" cut electric riding mower. It was made over 3 decades ago by GE named "Elec-Trac" and it carried 6 large LA batteries like the modern EZ Go golf carts. It was built with old technology relays with staged ,3 speed, resistors for field weakening speed control of the brushed shunt wound traction motor. The mowing deck was inconveniently in front with three direct drive 36 volt motors. It would mow several acres if the grass was not too high in the 2 hours you suggest. It charged with a large integral ferro-resonant 115VAC supplied isolating charger in a few hours, but a hydrometer was the best capacity predictor. Corrosion around the battery compartment was a problem. The best part was the absence of oily exhaust, but the machine was very heavy; it was rugged compared with a modern riding mower. The complexity of the tractor was something only to be appreciated by an engineer and I think this and its high price were the reasons it was not a big marketing success. A set of batteries cost several times more than a new 10 HP Briggs And Stratton engine which explains why you don't see them still in service.
Regards,
Luther M
There are old pilots and there are bold pilots, but there are no old bold pilots.
08/07/2010 9:44 AM
Now we are getting somewhere. Based on what I've seen so far, it looks like wheelchair batteries may be the way to go. Instead of buying an old wheelchair, though, what about just adapting an existing lawn tractor? I could buy an old tractor with a blown motor probably dirt cheap and go from there.
As for mowing it with a scythe or goats, I don't think my neighbors would appreciate it. It might work in Germany with their postage-stamp yards, but not on my one acre.
08/07/2010 11:06 AM
Many here have large areas of land, but they only cut what is needed, cutting it all for the sake of cutting is NOT environmentally friendly anyway.......let most of it return to nature!!!
08/07/2010 11:13 AM
I have a friend that did just that, but he lives in a more rural setting, and places where many live, the social climate does not allow 'not mowing'. In some areas that 'require mowing', choosing a slower growing species of grass or other ground cover might be more appropriate.
I have another friend that decided he needed to purchase over 100 acres for his family to live on, that way no one would expect him to keep that all mowed. ... He has planted, and harvested trees from much of it, but there are significant sink holes on his property so all the land is not tillable anyway.
08/07/2010 10:31 AM
Try this, Google "Electric Riding Lawn Mower" might give you some ideas, or places to buy one...
Good Answers: 141
08/07/2010 12:12 PM
No room for sheep? Wool, ticks, and good food almost free. Or geese, good security.
Plenty of room here
Good Answers: 458
08/07/2010 3:11 PM
Yup, we had one back in the seventies. Since my older brother worked at a lawn and tractor place, he brought one of these home. It was OK. I don't think I would buy one though, because if you had a big yard, it wouldn't do the whole thing on one charge.
http://www.elec-trak.org/
This thing had four batteries under the hood and two under the seat. I don't think it would do an acre of lawn though. Half acre at a time probably.
Cheers !!
Good Answers: 80
08/07/2010 3:58 PM
One have to realize the tremendous advantage that this application has to introduce new energy sources. It is not as glamorous than a car but it is much more accessible.
1-Only needs an hour or so of range.
2-Always near your own recharging station => no compatibility issues.
3-Nobody is in trouble if you don't finish the job on one charge. The work schedule can be adjusted by the owner. You don't need to cut twenty acres at a time.
4-Most law mowers pollute more than a small car. A low emission solutions would do real good.
Now, there are many posts on this site regarding new energy source that are difficult to apply to cars. They may work here:
A-Spring wound with a small electric motor. With enough gearing, we could get the spring loaded in a few hours. This would eliminate the nasty battery banks.
B-Compressed air could be used but is less efficient because of the large thermal exchanges.
C-Fly wheels.
D-Full or partial solar. Who cuts the grass in the rain anyway?
E-Wind energy anyone? The big blade at the top is geared up to rotate the blade underneath. Maybe difficult to cut near trees...
This could be a great project for the unfortunate ones who are unemployed at the moment. I would be willing to give some material and help to somebody working on something like that in Canada. I am sure that others would do the same in their regions.
Anybody ready to jump in?
08/07/2010 5:48 PM
Weed-eater used to sell a lawn mowing robot that was solar powered. It had a battery, but not much of one, just enough to get through a cloud going over or to mow under a tree. It was large and flat (think 20"x40" or so... that would be about 500x1000mm).
It was water proof, so you just left it in the yard during growing season. The problem is it didn't 'cut the lawn', it 'kept the grass cut'. Motors were light weight and wimpy power wise, but it seemed to work. Major problem was it was way to expensive for me :(
Still, I liked the concept.
Good Answers: 15
08/09/2010 5:45 AM
Have you seen these yet?
http://www.husqvarna.com/us/homeowner/products/robotic-mowers/husqvarna-robotic-mowers-for-homeowners/
scotchdrnkr
08/09/2010 8:19 AM
I was recently looking for a website with infos as to how energy efficient various battery types are and found a site that explained just how inefficient electric vehicles are, assuming coal fired power stations - which are still in the majority I am lead to believe.
24% efficient was the best figure........shockingly low.......and with a strong carbon footprint to boot (pun intended!)
So maybe running a petrol or diesel mower is not quite as unfriendly to the environment as we all (or at least me!) thought!!!
I have not marked this as Off Topic as I really feel that it is right On Topic with regards to an electric mower!!!!
Register to Reply 31 comments
ageniusforhire (1); Andy Germany (4); Anonymous Poster (1); Brave Sir Robin (1); cwarner7_11 (1); dvmdsc (3); energygod (1); Just an Engineer (1); Lo_Volt (1); Loupy (1); Luther M (1); lyn (1); marcot (2); MoronicBumble (1); Oregoon (1); RicinCinci (1); scotchdrnkr (1); servant74 (4); Slow Old Poop (2); szwasta (1); tcmtech (1)
