Previous in Forum: Distance Relay Test   Next in Forum: A Puzzle in the Wiring?
Two Wattmeter Method
08/09/2010 9:09 AM
Hey! Would anyone help me? What is the necessary formula derivation for 2 wattmeter method of 3-phase power measurement?
Re: Two Wattmeter Method
08/09/2010 2:11 PM
dear ,
Watts = (W1 - W2 )* MF ( i.e. scale factor) of meters * CT ratio
Exploring the Science of Electricity
Good Answers: 244
08/09/2010 7:05 PM
Using two wattmeters, the power can be measured for both balanced and unbalanced loads of the 3-phase 3-wire system. However, for the 3-phase 4-wire system (with having neutral), the two wattmeter method doesn't work for unbalanced loads. So, the two wattmeter method is supposed to be used for measuring the power of the 3-phase 3-wire system. The total power of the two wattmeter method is:
P = W1 + W2
Where, P = Total power, W1 = the power measured by wattmeter 1 and W2 = the power measured by wattmeter 2
It may happen that the values of both W1 and W2 are positive, or either W1 or W2 is negative.
For a balanced system, the power factor also can be calculated by using the 2 wattmeter readings with this formula:
tan θ = √3 (W2-W1)/(W2+W1)
For more detail for the formula derivation, see these links:
http://books.google.com/books?id=0QcUUlyUQjwC&pg=RA1-PA257
Similarly, the two element energy meter is used for measuring the energy used (KWH) for 3-phase 3-wire system.
See this thread http://cr4.globalspec.com/thread/56190 for detail.
- MS
