Previous in Forum: Need SQL Help   Next in Forum: PLC Programming
28 comments
Additional Operating System on My Computer
08/19/2010 7:26 PM
Hi, everybody! Can someone tell me how I can install two additional operating systems on my computer (if it is possible, of course). I've read about Linux and Google Chrome OS, but want to try them myself. So, can I install them in addition to existing Windows? If so, what should I do?
Thank you in advance!
United States - Member - New Member Engineering Fields - Electrical Engineering - New Member
Re: Additional Operating System on My Computer
08/19/2010 7:44 PM
I know it can be done through disk partitioning, but I have never tried it myself.
See if any of these google links on "How to Create Disk Partition" helps.
08/19/2010 8:10 PM
From what I read, Chrome is Linux based, so I'd skip that for now.
Find a reliable download site for Linux Mint, which I think is the latest. It will tell you the system requirements.
I have to warn you though, I did this and if you don't like it, getting it off and repartitioniing is a bit more complicated. A few points.
Linux and Windows will both work on one hard drive, separately. There is no communication between the two.
If you download and use Linux, you will also have to download new drivers to run printers, scanners, etc.
For people like me, that are not big computer nerds, there is a learning curve. Don't expect to get into Linux and have it be just like Windows, it's not.
That said, I did install it and had it running fairly quickly, BUT, I also uninstalled it. I just don't have time to learn a new OS. The people that take the time though, end up deleting Windows and never turning back. Good luck!
08/19/2010 8:25 PM
I tried it once. The Linux GRUB manager wound up hosing the XP install.
Windows can also mess with a Linux install.
The safest way is to use the BIOS to boot to separate drives which hold the different OS's. Also that way you don't need to run partitioning software.
08/20/2010 1:22 AM
You can install multiple operating system in a single computer in many ways. The safest way to do it is installing each OS on separate hard disk, not just a partition of the same hard disk. If you can afford to lost all files your hard disk, then you can go with partition and install different OS in each partition. I wrote a blog before on how to install Linux in Windows machine, you can check it out and I hope it can help. Here is the link: How to install Linux in Windows machine.
08/20/2010 7:01 AM
It just occurred to me this morning, I believe on the Linux site, you can download a scaled down version of Linux, which you can then burn to a bootable disc, without changing your hard drive.
You may want to do this first and make sure you like it before you take the plunge. I wish I would have.
08/20/2010 10:13 PM
Thanks to all of you guys; your comments are helpful. You said that some uninstall Windows going with Linux; That is exactly what I want to try. Just imagine, that every computer in school, university, or business is cheaper $100-150 just because of different OS! Plus free office (Open Office is completely free) can save you hundreds on every machine (depends on version of MS Office it replaces), and it works just as well as MSO! I think, it is a good idea to make any business cheaper and invest the money into something else, not into software that can be replaced with freeware... I don't say that MS software is bad, and we all got used to it, but it is hacking expansive! I have compared two offices (MSO and Open Office), and besides the appearing, they work almost the same and are compatible (sometimes presentations do not match when you send file from one office to another), but Open Office still can successfully replace MSO everywhere: at home, at school, or in business.
If someone has any idea about how difficult it is to start replacing software in big system, please share with us. May be you've tried another office programs that are cheaper or completely free and work better than Open Office?
Now it is very important for any business to buy cheaper... You know what I mean.
Thank you for your help!
Good Answers: 119
08/23/2010 9:04 AM
Just a correction and a note of interest:
Open Office is not a universal replacement for MS Office. Case in point: Autodesk Inventor will NOT work with OO spreadsheets, only Excel for table driven parts and assemblies.
There are other cases, I'm sure, but they escape me at the moment.
Hooker
08/23/2010 10:41 AM
Not even if you save the spreadsheet as .xls?
Good Answers: 119
08/23/2010 10:47 AM
Nope, not even then.
Inventor actually checks to see if you have Excel installed, then the version. Currently, Excel 2007 or newer is required.
Hooker
08/23/2010 11:01 AM
Ah, good to know. The last time I used Inventor was a couple of years ago, & didn't mess much with spreadsheet data. Thanks.
Good Answers: 119
08/23/2010 11:16 AM
You're welcome.
I kinda learned this info under extreme frustration as AutoDesk doesn't exactly advertise it. I have Inventor running under a home license on my laptop. The laptop had Excel '98 loaded on it and Inventor kept telling me that spreadsheet driven parts wouldn't connect. I then tried OO but still had the same problem (with all versions of OO).
It took some investigation to find out what was going on.
Hooker
Good Answers: 119
09/01/2010 1:26 PM
Yeah, it's crazy. Because Inventor maintains an interactive link between itself and the spreadsheet, you must have the app (Excel) itself installed and available.
The only way around that is to use Inventor's embedded table capability, which is painfully lacking if you have to maintain large tables of data.
Hooker
Good Answers: 213
08/23/2010 12:09 PM
OpenOffice spreadsheets also do not offer a Fourier Transform (as does Excel) either. Graphics in Excel are lightning fast when compared to OpenOffice Calc, as well. Nothing can beat Excel 2000 for a general purpose analysis package. But, fortunately, one can run Excel in Wine or VirtualBox or VMware quite easily...without sacrificing too much performance.
Another restriction with the Linux solution is that there are very limited CAD solutions available- the situation is improving with time, but if you are in to SolidWorks or Inventor or the like, you are pretty much held hostage by Windows...
Good Answers: 119
08/23/2010 1:39 PM
<sigh>Amen</sigh>
Not to mention my favorite online games.
Hooker
Good Answers: 213
08/20/2010 11:39 PM
I have on several occasions installed dual boot systems with Windows and Linux on a variety of different equipment, and have never encountered a problem. I always use the LiveCD (LiveDVD) procedure downloaded from the Internet to partition the hard drive- never encountered a problem (one must, of course, have Windows on the first boot sector, and one should clean up the Windows installation first- empty the trash, delete temporary files, etc, and then defrag). I have never encountered a need to use two hard disks for such an installation. I have also found that components that don't work under Windows (sound, Bluetooth, Wifi, etc.) suddenly start working again when loading Linux, without having to hunt down drivers, etc. Most printers and scanners I have worked with just work under Linux- the CUPS package that is a basic component of a Linux installation contains a large selection of drivers that are generally automatically matched to any printer you may have (although there may be some features of some equipment that may not be supported on occasion). Other components I have used (i.e., RS232 to usb adapter) just work under Linux, without the need for additional drivers, while under Windows, I generally spend a great deal of time searching for drivers for components that should work "out of the box". Of course, when working with a pre-installed Windows configuration, the manufacturer has already taken care of this. I have never encountered a problem with running the two operating systems on the same machine. (An interesting feature- one can access documents in the Windows sector from Linux, but not vice versa). I will admit, I have limited experience with setting up dual boot systems with Windows Vista, and no experience with Windows 7. There may be issues with these operating systems with which I am not familiar. I use almost exclusively Ubuntu releases, everything since 7.04, but not yet 10.04, with no problems. I have looked at some of the Ubuntu derivatives (Mint being one- Mint has the significant advantage of including proprietary Codexes that the Ubuntu purists will not include, if video is an important part of your computer experience. Others I like are CAELinux, an engineering package, and Vinux, a package specifically for the visually impaired, all based on Ubuntu). I have also looked at Red Hat (Fedora) and SUSE distros, but find Ubuntu preferable as a personal preference. SUSE appears more targeted at the enterprise. There seems to be more interest in scientific applications (finite elements, mathematics, biological applications, astronomy, etc.) in the Ubuntu community, but that perception may be the result of my personal interests. There is nothing really special about Ubuntu that would make it preferable for scientific applications, other than that seems to be where the community focuses.
There are over a thousand Linux distributions available, but there seem to be three broad classes- those derived from Ubuntu, Red Hat (Fedora) and SUSE. A good place to start is http://en.wikipedia.org/wiki/Comparison_of_Linux_distributions or http://en.wikipedia.org/wiki/List_of_Linux_distributions. These lists are not going to be up to date- it seems there is a new distro offered daily, if not more frequently. A lot of distros are now being offered for thumb drive installations as well- there is a special program that can build a bootable thumb drive from most of the popular distros (although I had better luck building a thumb drive with Ubuntu 8.04 rather than later distros). One still gets better performance, in my opinion, when running the package from a hard disk install rather than a LiveCD/DVD or a thumb drive.
I have completely removed older Linux distros that I no longer needed from machines without causing problems with other operating systems on the same machine. I have also installed both 32-bit and 64-bit distros on the same machine with not problems (of course, the machine must have a 64-bit system for this to work).
Exploring Linux is a whole lot more user-friendly than it was just four or five years ago...
08/20/2010 11:42 PM
Hi
Downlaod "Virtual Machine" software from Google (it's free by Oracle). Run it , it will create another partition in ur hard disk and you can install another operating system
Naveen Sharma
08/21/2010 1:40 AM
G'day,
Try Ubuntu Linux. It can be installed inside windows and still uses the (modified) boot.ini.
Best Regards,
Royce R. Vines
Imagination is more important than knowledge.
~ Albert Einstein
If thou cannot win by fair means ... cheat!
08/21/2010 4:48 AM
There are basically 4 ways of doing this, and I have tried them all. The first is to install the additional operating systems on separate hard drives and to remove and replace the hard drives as required. One of my machines has a tray and caddy system which makes this very easy, but otherwise this is for the people that like screwing their PCs (pun intended). The second is to run the second system from a CD. As noted, this works for a limited number of Linux distros but is relatively limited in speed and capacity. A more practical method is to use a partition manager (I used to use Paragon, free edition available at http://www.paragon-software.com/home/pm-express/download.html), with which you create separate partitions (can be on separate hard drives) and a boot manager to choose which system to boot up. Effectively you can have as many systems in parallel as you want, but when you want to switch between them you have to power down and restart. My favourite method is therefore to run one system *within* another system using virtualisation software. Again, a free version is available from http://www.virtualbox.org/wiki/Downloads. You start with a host system and then load the guest system, which runs as an entirely separate system, albeit rather slower, with control of the guest access to the host system. For those of you with Macintoshes, my current setup is (paid-for) VMWare running 5 different versions of Windows and some Linux, all as guests under OS X. Switching between guest and host is instantaneous.
Good Answers: 213
08/21/2010 11:20 AM
I also run Windows in VirtualBox on one of my Linux machines. There is a loss of performance with this set up, but for some applications this is trivial. Switching between systems is instantaneous, however, and it is possible to share data between the different operating systems...
One issue I have had- it can be more difficult setting up a Virtual system for a novice. It is much easier to set up a dual boot system. I have not had to use anything other than the partitioner that comes with the installation package with Ubuntu for years, and the GRUB boot loader is very stable and easy to use.
08/21/2010 4:56 AM
Not sure about Chrome but I have used Wubi to install Ubuntu on 2 of my PCs with complete success. On boot, you have the choice of using Windows or Ubuntu. To remove it, you just uninstall Wubi (having saved any of your data wanted)
wubi-installer.org
Steve
08/21/2010 6:39 AM
The Oracle Virtual Machine Is Free o Download And Lets You Mount Several Operating Systems Within Windows or Linux Depending on The Version You Download.
morloch
08/21/2010 2:44 PM
I'll write down the steps I took yesterday to install Ubuntu 10.04 alongside Windows 7 (which was already installed, and was occupying the whole hardrive) on my girlfriend's netbook yesterday:
  1. Download Ubuntu 10.04 (700 MB). http://www.ubuntu.com/desktop/get-ubuntu/download
  2. Create a LiveCD on an USB flash drive (you need at least 1GB & it's easy, since there's an app to do this. Check step 2 on the above link). You can also burn it to a cd, but I didn't do that.
    RECOMMENDATIONS: Before going further, backup the files you want to keep (burn to a cd/dvd, use an external hdd, flash drive, etc), clean your trash & defrag your drive.
  3. Boot from the LiveCD to do a test drive. You might need to change the BIOS boot priorities.
    WARNING: AFTER you partition your hard drive, you NEED to restart your pc and log onto Windows to let it rescan your system, BEFORE installing ubuntu.
  4. Partition the hard drive using GParted (it's included on the Ubuntu 10.04 LiveCD, under System>Administration). Reduce the size of the windows partition and leave unallocated space (for ubuntu). You need about 2-3 gb to install ubuntu, but leave extra for more applications/files. How much extra depends on you. You can always resize all partitions anyway.
  5. Restart your PC and let it boot to windows. It will do a system scan.
  6. Reboot to the LiveCD.
  7. Install to the biggest space available on the hard drive.
And that's it. When you restart, you'll be prompted to choose which OS to boot.
08/23/2010 12:02 PM
As I recall you can install Linux as an "App" under Windows XP, just like any other app. Doesn't require partitioning. The main hang-up is reading and writing to an NTFS volume. Reading was reliable a couple of years ago, as I remember. Writing may or may not be yet. Just some considerations.
09/01/2010 4:56 AM
You can install linux under XP using Wubi and does not require partitioning. There is no problem reading and writing to NTFS volume. Using Ubuntu software center download/install the ntfs-3g and the NTFS configuration tool. The configuration tool will allow mount/unmount your ntfs automatically or with one click to access the nfts volume. Normally you cannot access linux file from windows, but there is a free program to do this. I forgot the name, but google this. But for me, for security, I would not want windows to access my linux files.
09/01/2010 5:18 AM
If what you say is true, I would guess that the disk also needs to be in FAT32 as Linux can have serious problems with NTFS (the normal format for XP!).
Good Answers: 119
09/01/2010 8:41 AM
No, Linux works fine with NTFS in my experience.
I've even used Ubuntu to fix a damaged Win XP NTFS file system with tools that MS does not provide.
Hooker
Good Answers: 213
09/01/2010 1:09 PM
I, too, have accessed and repaired the NTFS file system from Ubuntu in a dual boot configuration, with no problems. I do not, however, write to the NTFS file system from Ubuntu, which I believe is where most of the problems arise...
Good Answers: 119
09/01/2010 1:22 PM
I haven't done extensive file access from Linux to NTFS so I guess I've just been lucky enough not to have seen any problems.
I suppose since I've never had any problems with this that I've never had a need to go out and see what kind of problems may occur. Ignorance is bliss.
Hooker <-- with fingers crossed
Register to Reply 28 comments
Andy Germany (1); Anonymous Poster (4); Ca-Vin (1); cwarner7_11 (4); gfmlcka (1); Hooker (7); Jaxy (1); kramarat (2); morloch (1); phph001 (1); repnitskiya (1); RTFVerterra (1); V.Daniel (3)
