Previous in Forum: Difference Between Voltage and Watt?   Next in Forum: Excitation Current of AC Generator ?
Transformer Question
09/20/2010 6:40 AM
I have a transformer with 110/230V primary input and the transformer is rated 80VA, how do I know its output voltage?
Please help.
Re: Electrical
09/20/2010 7:02 AM
check the winding ratio ... if it is 2.0 then it is a step down divide voltage in half. If it is a 0.5 it is a step up ... doubles the voltage. So the winding ratio is inverted to tell you to either divide or multiply the input voltage.
Good Answers: 181
Re: Electrical
09/20/2010 7:12 AM
Read the label!
Re: Electrical
09/20/2010 7:34 AM
my dear if isolated transformer Pri. and Sec. and there is 4 wire ,you can do by ohm chek,230 v side would be about 4 times more in compair with 110v
if autotransformer it is'nt isolated and there is 3 wire two wires with more ohm is 230 v side
take care with voltage shok both
India - Member - design engineer Engineering Fields - Electrical Engineering - New Member United Arab Emirates - Member - New Member
Re: Electrical
09/20/2010 7:44 AM
use a voltmeter at o/p terminals
shamith gambhir, electrical engineer
Good Answers: 140
Re: Transformer Question
09/20/2010 12:04 PM
If you do not want to power up the transformer, take the part number of the transformer and go to the manufacturer's web site.
09/21/2010 3:18 AM
Energise the primary and measure it!
09/21/2010 8:33 AM
use a voltmeter to measure secondary voltage
Anonymous Poster (3); North of 60 (1); PWSlack (1); SHAMITHGAMBHIR1 (1); TonyS (1)
