Previous in Forum: Sizing a Diesel Genset   Next in Forum: Motor Starter
Generator for Microhydroelectric Power Generation Station?
11/05/2010 6:10 PM
Smart People,
I am designing a microhydroelectric power generation station. The station will be located at the concrete outfall of an existing pond in a small, urban watershed. The site is at an existing dam with 9+/- feet of available head. The base streamflow is 3+/- cfs and the maximum flow that will be utilized is 23+/- cfs. This translates to roughly 1.5kW base power potential and 14kW maximum power potential.
The proposed system schematic is as follows:
Reservoir --> Waterwheel --> Generator --> Inverter --> Grid
The most suitable power converter in terms of overall performance (cost, efficiency, maintenance) is a breastshot waterwheel (18+/- ft diameter). Breastshot waterwheels are most efficient when converting potential energy into 'mechanical rotational energy' (as opposed to kinetic energy to 'mechanical rotational energy') – in practical terms, this means the waterwheel is most eff8icien ct at slow rotational speeds. Ideally, I'd like to have a base waterwheel rotation of 1 RPM, which would roughly result in a maximum rotation speed of 7 RPM. Assuming I could achieve a 40:1 gear ratio, this would be a base generator shaft speed of 40RPM and a maximum generator shaft speed of 280 RPM. As this is an urban watershed, the flow (and thus power output) is highly variable. (I could go beyond the 23+/- cfs input, but I am limiting it to this due to various civil/mechanical reasons).
With all that, I have the following questions:
1) Is the "[DC] Generator --> [DC-to-AC] Inverter" portion of the system schematic what I should be looking at or is there a better system? I've seen various systems, but this seems to be the most straightforward, efficient, and (assuming I can find the generator) least expensive and most viable option.
2) Does anyone have a suggestion for the generator I should use? I've looked around, but haven't found much. I am guessing that I will need to find a high torque / low speed (multi-pole) DC motor used for mixing or grinding operations and run it as a generator.
I searched the posts and the closest one I found I found was the 2008 thread on 'Converting AC to DC for a micro-hydro turbine', but that didn't was a bit different...
Any help is greatly appreciated!
tsgrue
Pathfinder Tags: electric Generator hydro micro motor
Good Answers: 19
Re: Generator for Microhydroelectric Power Generation Station?
11/06/2010 12:09 AM
Good. Send me your finished drawing.
11/08/2010 5:12 PM
What do you mean by 'good'?
Thanks!
Good Answers: 181
11/06/2010 3:26 AM
See http://cr4.globalspec.com/thread/62085/240volt-from-12-24-48v
There will be other as well if you use CR4 search.
Register to Reply 3 comments
ducon (1); TonyS (1); tsgrue (1)
