Previous in Forum: Jeep Grand Cherokee 95 Problems (Not Wanting to Start)   Next in Forum: Just for info
20 comments
Why Not Use Permanent Magnet Rotor in Motor or Generator?
11/13/2010 3:59 PM
Rather than use slip rings or a commutator with all the trouble these things bring ...why not use permanent magnets for the rotor in a motor or generator and collect the A.C. from the field coils? Is this done in any cases? Thankyou for reading. David in Wales U.K.
Re: Why not use permanent magnet rotor in motor or generator?
11/13/2010 4:03 PM
Because they are not adjustable for voltage regulation.
11/13/2010 7:11 PM
Thanks for reply. I see that....but I suppose one could switch in and out field coils and so change the voltage that way. I know that would give steps of voltage change rather than smooth control. I realise I dont know much about this topic and I have been trying to look around the internet.
Good Answers: 141
Re: Why Not Use Permanent Magnet Rotor in Motor or Generator?
11/13/2010 8:47 PM
They exist under 'brushless' motors. In the smaller power range. A stepper motor can also one be one. They require some electronics to make them spin.
Plenty of room here
11/14/2010 10:32 PM
Yes you are right. I have seen photos of these where the rotor is on the outside of the stationary electromagnets. Thanks for your post. david.
11/14/2010 12:11 AM
Permanent magnet generators are used in
(a) Small wind generators.
(b) Generators which operate on constant load & therefore voltage regulation is not a criteria.
(c) Any application where electronic control is available downstream for voltage regulation and output of this control device is used to supply load.
As has been mentioned already, power rating is generally upto few kW.
Thanks and regards
Ashok Toshniwal
Location: "Springwood", North Tamborine Mountain. Qld. OZ.
11/14/2010 1:44 AM
David,
We have been using this technology for more than 10 years.
We generate using a permag rotor, rectify and invert it to 240vac, then add frequency.
It gives us ac power without having to be concerned with engine revs. Actually, it's a boon, because we throttle down for light load periods, and the frequency is always exactly correct at the load. Better quality power that from the grid, really.
It's also the basis of the modern 'inverter' generators, which have now become popular.
Added bonus is that they're quieter when throttled back.
"Nothing, is as it seems." Dr Wally.
11/14/2010 4:00 PM
David,
I have re-read my post and it contains a couple of typos.
1. Is the omission of the indicator ' to DC', after 'rectify'. So, it's "rectified to 240v dc" and the the frequency, Hz, is added.
2. And, it's better quality power 'than' from the grid.
Sorry,
Cheers, Stu.
11/14/2010 10:27 PM
Thanks for your reply. I saw that your post had a few typos but I had understood your meaning anyway. I will look up the modern inverter types. Thanks. david.
11/14/2010 10:10 AM
google "magneto"
11/14/2010 10:43 PM
Yes, I had thought of magneto.. but for some reason I thought these were spinning coil rotors inside stationary magnets...my assumption could well be all wrong and I will go to google to find out. Thankyou for your post.
11/11/2011 7:30 AM
Most all of my motorcycles use a spinning spinning magnetic rotor with the coils dispersed around it in a radial fashion. Usually not all of the coils are wound allowing different different output voltages depending on the number of coils that are wound.
Google 'stator motor' under their Images heading.
Good Answers: 54
11/14/2010 5:12 PM
Using PM's in the rotor is common. However, using electro magnets means you can get a much higher magnetic flux hence higher efficiency.
Like many engineering designs there is a tradeoff between initial cost, operating efficiency, reliability, maintenance cost and size/weight.
If there's something you don't understand...Then a wizard did it. As heard on "The Simpsons".
11/15/2010 12:04 AM
Si hoc signum legere potes, operis boni in rebus Latinis alacribus et fructuosis potiri potes!
Good Answers: 74
11/15/2010 12:53 AM
If I may Bumble
It leads to this.
http://www.windbluepower.com/category_s/56.htm
The Twain Has Met
Good Answers: 458
11/16/2010 9:57 AM
Motorcycle engines typically use permanent magnet generators but have to use a shunt or pass regulator to maintain the correct voltage. You will usually see the regulator with a bunch of cooling fins to dissipate the excess energy produced, especially at higher RPM's. Electrical loads are usually pretty well defined so the designer doesn't usually have to worry about "add-ons" and can size the generator to be just large enough. Admittedly, this is inefficient but the process of adding brushes and slip rings for a field coil doesn't make sense given the reduction in reliability and increase in costs. I'm sure larger touring bikes probably have a more sophisticated alternator to handle all the extra electrical loads.
11/16/2010 10:25 AM
Motorcycle engines typically use permanent magnet...
This might better read: Small motorcycle engines often use...
Many of the mid-sized motorcycles you see on the road in the US (from about 350cc to 1000cc or so), which tend to be on the large side vs, for example, those in India or China, use alternators in which the fixed field coil magnetizes a rotor (which looks like the rotor in a car alternator, but without the field coil and brushes), which, in turn induces a current in the charging coils. No brushes, can be bathed in oil, can be regulated etc. Neat design, simple, but I'm guessing not as efficient as the car style, because:
Some larger-yet motorcycles use air-cooled alternators like those in a car.
Good Answers: 19
11/16/2010 5:50 PM
I got 1820cc's and my alternater is just as you described. It is a large touring bike with great gas mileage.
11/22/2010 10:01 PM
'Permanent' magnets wear down if the polarity isn't periodically reversed.
01/18/2011 8:15 PM
Something like this would work...
06/27/2014 1:14 PM
permanent magnet r not used because we can change the voltage by elctro magnet but we cant change with permanent magnet and there is other reason is that there is more hysteresis loss in permanenet magnet
Reply to Forum Thread 20 comments
129CBRider (3); Anonymous Poster (6); ashoktoshniwal (1); Brave Sir Robin (1); dvmdsc (1); ffej (1); ky (1); MoronicBumble (2); silvCrow (1); Stueywright (2); Tornado (1)
