I have read in several post on the EVGA forums describing how to return a GPU to use after overheating damage if the damage is not to severe (limited to bad solder connections).
In my case a few months back NVIDIA aparently released a driver that caused GPU's to overheat (noted in the NVIDIA forum). I believe this happened to my GPU's and before I could shut the system down the temps climbed to around 95 degrees celsius. Temp max for my GPU's are at 90 degrees celsius with an operational range of 70C to 90C.
Now one of the GPU's will not boot standalone (my system sees it as being in the wrong PCIe slot) and can only be used with another GPU in QUAD SLI mode where it loads and shows to be working properly. In addition I have been experiencing numerous crashes (black screens, frozen images, and infrequent green multi-line screens) which sometimes recover and allow the PC functionality but they never recover completely to continue game play without shutting down and restarting the my simulation.
After the issue with the temps I installed a different driver which resolved the high temperature issue. Aparently some damage had occured and I am thinking of trying some of the suggestions I have read about on the EVGA forum, specifically oven baking the GPU's to allow reflow of the solder connections. The suggestions at the EVGA forum are from non-technical users and some technical experiance would be valuable prior to undertaking this task.
I am wondering if anyone here has tried baking a GPU (or other electronics board), how it was done, and what the results of the process were? I am at a point where I am tired of the crashes, interruptions to the simulations, loss of simulation position and place in process, and would like to avoid the cost of new GPU's which could be damaged by a bad driver anyway.
My hope is to build enough confidence so I can attempt this recovery method (or another).
What are your thoughts and suggestions on this? I have not ruled out completely that there may not be another problem (note: everything was fine prior to the bad driver) please do not hesitate to share your experiance if you have had issues of GPU's crashing in game, simulation, or other use.
I am running 2 GeForce 9800 GX2 GPU's in Quad SLI mode on a 790i ULTRA motherboard. For those not familiar with these cards each card has 2 graphics processors and allows them (by design) to run in QUAD SLI mode.
EDIT: As an aside any link to other technical or engineering forums dealing with correction and restoration of board overheating could be a real plus in finding an answer.
