Previous in Forum: Retain Water   Next in Forum: Turkey Day
16 comments
Accurate Measurement of a Solder Iron Tip?
11/24/2010 8:10 AM
I have been conducting a search for the best means for measuring the temperature of a soldering iron tip, with a measurement accuracy of ±5°C. The measurement range will likely be between 175°C and 400°C.
Unfortunately, the high end of the range on my DMM with thermocouple is 200°C, but I am considering obtaining a higher range temperature reader. I am a little concerned with the consequences of stem effect caused by the thermocouple, but this is looking like my best option.
Another option would be to use an IR gun. We have a Fluke 63, but I am having a lot of trouble obtaining a consistent reading. I think a lot of this has to do with the averaging effect and the distance I am holding the gun from the thermocouple, but either way, I am not too confident in the results.
I am hoping that I could draw on the experience of the community here. Is there something that I am missing in terms of temperature measurement? I have to add that this will be used for a "controlled" laboratory testing and only needs to be a temporary setup, although permanent would be welcomed. I am trying to run a test evaluating the effect of changing Ag content in a solder on Ag scavenging from a metallization and would like to add temperature variation as an additional variable.
Thanks in advance!
Re: Accurate Measurement of a Solder Iron Tip?
11/24/2010 8:56 AM
I don't think one of the smaller thermocouples (e.g. click here) would significantly affect the tip temperature or measurement of it - the ones I've linked to have wires only 0.3mm in diameter.
Good Answers: 918
11/24/2010 9:12 AM
Weller makes exactly what you want, but it is pricy.
Techni-Tool sells THIS.
Systems like the above are generally used for compliance to certification standards.
If you simply desire to know the tip temperature because you are curious, a thermocouple and a DVM can do it pretty well at a cost that is relatively cheap.
However, if you are trying to show compliance to some industry standard in your experiment (i.e., ANSI-J/D.O.D.-2000), then a calibrated measuring device like Weller's is going to be the right tool.
11/24/2010 10:06 AM
Back in the late 60's at Sprague Electric, we did a lot of soldering with gas-fired soldering irons as part of the manufacturing process of a wide variety of capacitors, and had a department that made our own tips in a variety of sizes. The tips were made from copper rod, and were plated with cadmium or nickel. A number of studies were conducted at that time using thermocouples embedded in the tips. Unfortunately, I have none of the data from that time to be able to advise on any details.
Engineering Fields - Electrical Engineering - New Member United States - Member - New Member
11/24/2010 10:47 AM
Someone on Ebay is selling Hakko model 191 tip tester/termometer for only $21! A quick search shows this is not an active product for Hakko, but these are new. Not a bad deal.
Link
Down side, the seller is in Taiwan, but free standard shipping is included, probably take a couple weeks to arrive.
Hope that helps,
Tom D.
11/25/2010 2:14 PM
Thanks for the link. I asked our Sourcing Manager to purchase one for me and the low cost allowed for an easy transaction with little arguing required by me. Cheers!
11/29/2010 8:32 AM
My pleasure, always nice to be able to help, even nicer when it's acknowledged :) Thanks for the GA.
Tom D.
Hobbies - Musician - Tube Amps Only Please!
11/24/2010 10:39 PM
Try a heat meter were you point at the heat source and measure it. They sell these at major electronics companies but I do not know the accuracy of these devices but they are used to look at hot spots in electronic equipment just point and measure without even touching the device!
Regards, Maveric Manic - 'Knowledge is Power and Wisdom is knowing how to use it'
11/25/2010 12:42 AM
I would go with one of the many laser/infrared "ray guns" These non contact units are available for a couple of hundred dollars(US) or less and can be used to measure the temperature of just about anything. Ed
11/25/2010 3:48 AM
Sadly you did not mention if you want a variable temperature at the tip or a fixed - always the same - temperature.
This makes considerable difference to the answer you need......
Please always mention full details as you know them, that way you will most likely get an answer that helps you further, far quicker.
(You are not the only one only giving a percentage of the required infos, I would suggest that at least 90% of the original posters make the same mistake....so don't be surprised or offended....)
11/25/2010 4:21 AM
Andy - he is asking about measuring the temperature.
11/25/2010 8:59 AM
But for what reason John?
Does he need to make sure that it is a a particular temperature or does he want to dial in a temp and know when it has got there.....or is he just checking such units for accuracy?
I have a variable temperature soldering iron with a display of the temp I want and the one achieved.
Naturally they should (and do) end up identical.
Its great for most types of soldering, even lead free is just achievable. Plenty of different tips available or "file your own!".....
It cost new less than €40 ($60?), which is a gift, so I would not want to make one. Look here:-
http://www.pollin.de/shop/dt/NTQ5OTUxOTk-/Werkstatt/Loettechnik/Loetgeraete/Loetstation_ZD_931.html
11/25/2010 2:12 PM
AG - This is a fair assessment of an inadequate query. I am looking for a measurement of the fixed temperature. I will be changing the temperature, but allowing the system to reach equilibrium. Also, it should be noted that I am not looking for a NIST traceable measurement. That is likely to be important to others.
11/25/2010 6:48 AM
I had been using a professional Variable-Temp Soldering Irons tip temperature measuring Equipment. Try Wellers [one of major manufacturers of Soldering Equipment, my company was using & testing also] or Fluke.
Normal DVMMs are using accessories for such measurements are like Panel Meter just for an approximation not accurate measurements. If you are using a Fluke or Tektronix or HP DVMM they have a vast range of accessories to extend such testing facillties.
I am out of touch practically at this age and can only refer to sources I had been using in my practical life.
Hope you could search or enquire from some of the vendors of above manufactures equipment. Rs & Farnells are some of those and Maplin is a retailer & if there is in your location have a visit and are helpful people.
Good luck.
11/25/2010 7:23 AM
Try SL-30 or SL-30A on internet, you will find someone in you area selling this reasonably priced digital display soldering iron it indicates tip temp or set temp and at 48W has quick recovery. Adjustable between 170°C and around 450°C.
Good Answers: 58
11/25/2010 8:30 AM
The infrared gun would be a good method if you could fill the field of view with the tip. This leaves the thermocouple as your best option. I suggest you use a small type K thermocouple (maybe 0.1 mm). I like to drill a small hole in the tip and either swage or braze the thermocouple bead into the hole. It's not necessary to make a thermocouple bead and attach it to the tip. If you prefer, you can attach one thermocouple wire to one side of the tip and the other wire to the other side of the tip. The reading will be the average of the two junction temperatures. You want to avoid attaching a large thermocouple bead to the tip surface because the junction will operate at considerably lower temperature than the tip.
02/11/2026 12:25 PM
Register to Reply 16 comments
Andy Germany (2); Anonymous Hero (1); Anonymous Poster (4); Haajee (1); JohnDG (2); kfitch7275 (2); maveric_manic (1); tdesmit (2); welderman (1)
