My engineer husband thinks I'm nuts because I think there is an invisible fracture in the Pyrex caraffe in my coffee press, which sometimes opens up and leaks coffee when under heat and pressure. Here's the strange part. I can use the coffee press a dozen times without incident. But occasionally, it's harder to press the plunger to force the screen down within the caraffe to filter the grounds from the brewed coffee, and when that happens, a small amount hot coffee somehow leaks from somewhere near the bottom of the glass caraffe. It is not bubbling up out the top as my husband claims, nor is it old coffee from a previous brewing that was trapped between the caraffe and the metal frame.
I suppose I should throw the caraffe away before it explodes and spews hot coffee. Right? When washed and dried and held up to light, no crack is visible.
