Previous in Forum: # of Mechanical Operations for Disconnect Switch   Next in Forum: Real Electrickery
Traction
12/12/2010 9:25 PM
plz describe the how the power transmitted in traction system & why we used two overhead line in traction which is not earth wire.
Good Answers: 181
Re: traction
12/12/2010 9:41 PM
"why we used two overhead line in traction which is not earth wire"????
Usually there's only one O/H wire the return path being the rails.
Unless your referring to a trolley bus system.
Re: Traction
12/12/2010 10:31 PM
Read any books in the subject of Electrical power utilization.
Re: Traction
12/13/2010 10:06 AM
there is only one line of 25kVA is used in traction system.
the other line was used near the railway platform to bisect the main supply from the train to avoid the traffic in railyways.
and the track is used as a neutral or earth.
Re: Traction
12/13/2010 10:34 AM
I believe a two wire system was tried way back using 3 phase power. It may have been used on single phase to eliminate electrolysis of underground pipes.
Mr.Ron from South Ms.
Anonymous Poster (2); ronseto (1); sandeep kumar (1); TonyS (1)
