Previous in Forum: LG Monitor Problem   Next in Forum: File Conversions to a Format Playable on Regular DVD Player
17 comments
Image Processing Software
01/03/2011 9:21 AM
I am looking for software tool which can measure images geometrically like dia, angle, length, etc. I want ready made tool which I can modify & use for my applications like measuring small components. Is anybody have idea about it, some softwares are available in the market but I want to create my own program. Any suggestions are welcome
Re: Image Processing Software
01/03/2011 2:57 PM
You might try searching "comparators"; there might be some with microprocessor or computer interfacing.
01/04/2011 3:28 AM
You don't mention what format your images are in or what size they are. However, have you considered using a CAD tool?
treaney
01/04/2011 11:34 AM
Thanks for your comment, Image format is either jpg or bmp, can you explain how CAD tool will help? My purpose is to capture a image of any component with the help of CCD camera & measure it geometrically with the software.
01/05/2011 5:10 AM
All CAD packages have dimension tools (both linear and angular).
AutoCAD is the industry standard CAD package, but, is very expensive.
The file extension for AutoCAD drawings is DWG, and, most CAD programs will do a reasonable job of importing DWG files, but, they invariably lose the scaling when they import.
AutoCAD LT (lite) is the 2D version of AutoCAD but is still horrendously expensive.
DoubleCAD XT is an extremely good 2D CAD package with the "look and feel" of AutoCAD LT plus some of the advantages of its "sister" product TurboCAD. You can get the free version here:-
http://www.doublecad.com/Products/DoubleCADXTv3/tabid/1100/Default.aspx
Your big problem is getting the correct scale into your CAD drawing. If I was you I would include an object of known exact size in the photo.
Once you have a .jpg you can import it into open office (text) then export it to a pdf; use aide pdf to DXF converter to get a CAD file then import that into DoubleCAD.
Now you will need to scale the whole drawing so that your reference object is the correct size. Finally use the dimension tools in DoubleCAD to do the measurements.
01/04/2011 5:19 AM
You should have a go with ImageJ, it's OpenSource and has many existing plugins (try the Measure and Label one for a start)
01/05/2011 1:48 PM
Wow: impressive free software package, with excellent documentation.
http://rsb.info.nih.gov/ij/download.html
I'm not sure yet how relevant it is to the OPs (Original Poster's) problem, but Good Answer anyway.
01/06/2011 7:17 AM
Yes indeed it depends on the OPs starting point. I used it quite a lot to analyse Microscopy images while at University to measure nanosize features. You can adjust the image properties (sharpness, greyscale...), set your own scale and automate the process by creating shortcuts. It can create a list and label the items on the image, good when you do 100+ measurements from 1 image. The documentation is excellent and with the wide variety of plugins, you could tailor them for your particular applications as suggested by the OP maybe.
01/11/2011 4:14 AM
I have to measure image captured through a CCD camera, it could be a jpg or any image file. I want to know if there is any development tool for creating any image analysis software.
01/11/2011 10:11 PM
Check for
Irfanview All free
Following not only this claim but I am using it since it just started from raw.
lots of plug-inns may guide you to work and also plays some more common videos & audios [including SWF.
Have a look. I am not advertizing it but I am fan of it. IT IS TOTALLY FREE & real updates but not frequent.
Stand-Alone Not to be installed. Even it installed copy the folder and play from any portable disk by clicking a shoert cut
IrfanView is a fast and compact image viewer/converter. It is trying to be simple for beginners and powerful for professionals. Many supported file formats and features. Features include: multi-language support, Thumbnail option, Painting, slideshow, toolbar skins, fast directory browsing, batch conversion/editing, multipage editing, file search, change color depth, scanning, cut/crop, IPTC edit, capturing, lossless JPG operations, effects, ICC support, EXE/SCR creating, many hotkeys, command line options and plugins.
The program lets you open and edit images, as well as multiple media formats. You can cut and crop images, apply batch conversions, add, sharpen, or blur effects, create panoramas, and change color modes easily. The program continues to add support for an array of file formats and has plug-in support for most image, video, and sound formats, including MP3, AVI, audio CD, and WMA
01/11/2011 11:29 PM
Sorry ! The link was not to Homepage of Irfanview
IrfanView
01/04/2011 5:47 AM
Aide pdf to DXF converter is less than $200
http://www.aidecad.com/pdf-to-dxf-converter.html?gclid=CPSctJauoKYCFQ8f4Qod_3aRaA
I have used the trial version and am very impressed.
There are lots of free ways to get a pdf from almost any kind of image.
Of course you would need to "scale" the resulting drawing.
01/05/2011 11:35 AM
Go to for information.
I am using Free but you may need Pro:
JRuler.exe
http://www.spadixbd.com/jruler/?referrer=JRulerProUser
JR Screen Ruler <http://www.spadixbd.com/freetools/jruler.htm>
JRuler Pro 3.1
http://www.spadixbd.com/jruler/index.htm
08/06/2013 6:01 AM
As for myself, I used to do tiwh image processing work with the help of a fine 3rd party image processing SDK. It is just one of many but I do appreciate its simple way of processing. Even though I only tried its free trial package to process images and didn′t check the cost and licensing conditions, it worked great for me. Besides, this site gives a lot of tutoials for processing different kinds of document and image formats. Share with you. And I hope you success. Good luck.
Best regards,
Arron
12/26/2013 10:44 PM
i have download one in my pc. maybe you can use this image processor or google on the web and try out other applications.
12/27/2013 1:54 AM
Try Foxit, there's a free version. I use for measuring drawings in PDF, angles, lengths etc.
Tony
The nice thing about Standards is there are so many to choose from.
02/25/2014 9:50 PM
i haven't tried foxit yet, but i will gladly to have a try. and see which image processing application is better.
more about image processing software
02/25/2014 11:10 PM
I visited Raster Edge and it looked complicated, please write about your experiences with it.
Tony
Register to Reply 17 comments
adlike (2); alyrian (2); arronlee (1); Haajee (3); Randall (3); Tonymech (2); Tornado (1); treaney (1); vertexmachines (2)
You might be interested in: Tool Posts, Tool Racks and Tool Trays, Tool Balancers
