Some questions on the basics:
1. What is the most common mode of failure caused by a hole drilled into the web of a beam near a flange. Buckling near the hole?
2. Does the pressure from a nut-bolt-washer in & over the hole increase strength by preventing buckling?
3. What is the off-the-shelf "classic" solution to beef up the area around the hole assuming the hole must remain open? Something like a threaded collar seems like it could do as well as a nut-bolt.
4. Is there anything on the market that can bring the beam back up to its original strength?
Bret Cahill
