Previous in Forum: 60's NOS RFT ECC83 (12AX7) - Marking Identification   Next in Forum: Modal Analysis of a CAD Model
29 comments
Building a Chlorine-Free Desert Swimming Pool
01/24/2011 9:05 PM
Yes, I'm afraid this project IS as crazy as the title suggests.
In July this year I am tasked with creating an temporary Oasis in the middle of the Spanish desert as part of a culture festival. The center of this oasis is set to be a 14ft swimming pool containing 14.39 m³ / 14300 litres of bathing quality water.
The problem is that the water cannot be chlorinated due to the sensitivity of the local environment. I am therefore going to have to rely on filtration to maintain water quality.
Compounding the problem is the fact that the source-water will be drawn from a local river and may already contain normal river contaminants. There is also likelyhood of considerable desert dust entering the water due to the occasional gust of wind. Lastly participants will likely recieve only the lightest of hose-downs before leaping in and will therefore bring sweat / suncream in with them.
With a permenent or semi-permenent pool I would give up the idea as foolish, but this instalation only has to survive for 10 days and, if absolutely necessary, the water can be replaced part way through. I'm therefore guessing with the right filters I can keep the water clean enough for the duration.
I've read a number of swimming pool posts on the forum and have decided you guys are the best to ask. Any advice, comments or suggestions are welcome.
At the moment I'm proposing to use:
Sand Filter > 20 micron cartriage filter > Active Carbon Filter
The logic goes: Taking water fromm the pool, the sand filter will remove the majority of the dust and any large sediment. It can be regularly flushed. The cartriage filter will remove the remaining dust and smaller particles. The AC filter will tackle any remaining microorganisms returning relatively clear bathing quality water to the pool.
Would you consider this sufficient? Will the AC alone be sufficient to tackle organic nasties? What would you change?
Cheers!
Tass
Re: Building a Chlorine-Free Desert Swimming Pool
01/24/2011 9:48 PM
Maybe an ozone or ultraviolet treatment along with these others?
01/26/2011 12:37 AM
UV treatment will probably be the better option. Bromides and QAC's have lasting effects and would only be absorbed back into the system by dilution. Chlorine could work if you drained the pool to a separate resevoir and let the sun take care of the Chlorine before re-introducing it back into the river. regards.
Good Answers: 101
01/25/2011 12:08 AM
You can also use a low power DC electrolysis unit with copper terminals. This will introduce copper ions that will kill the bacteria into the water.
Good Answers: 97
01/25/2011 1:50 AM
Diatomaceous earth
01/25/2011 8:33 AM
You could use one of the new salt water filters they have out there. They're a little expensive but I was thinking about getting one myself. They say you don't need any chemicals at all running this sort of system. Worth checking out don't you think?
“If you forget you have to struggle for improvement you go backward.”
01/25/2011 10:14 AM
Are you sure it can't be chlorinated?
My thinking is, that since it's short term, a gallon of household bleach could be added at night when the pool is closed. It would kill the germs, and it is very quickly neutralized by sunlight, rendering it harmless.
Environmental impact would be zero. http://en.wikipedia.org/wiki/Bleach
01/25/2011 10:46 PM
Bromine is often used as an alternative to chlorine. It performs well in hot water which you will have following the first day in the sun. You might add aerators that could be run at night thus cooling the water to help reduce the ideal conditions for algae growth. Gary
01/25/2011 11:28 PM
Use a UV of 14m3/hr and a cartridge filter instead of sand filter with a pump of discharge at 14m3/hour.
waterparks
01/26/2011 2:27 AM
My friend why not use chlorine injector before the sand and cartridge filter then dechlorinator after the filters, in this way you don't have chlorine intering the pool. One example is the sodium metabisulphite.
Chito
Good Answers: 213
01/26/2011 2:30 AM
Several good suggestions here. The UV or Ozone option (of comments 1 and 8 above) would be quite practical for a short term application- although there may also be some environmental issue over ozone (there is the possibility of ozone release to the atmosphere if dosing/injection/contact time are not properly controlled. Although I have a personal preference for ozone generation, UV would likely be cheaper to implement and would be quite effective (assuming proper control of flow rate) for the short term of this project.
The salt/chlorination (comment 4), electrolysis (comment 2) or ionization processes (not specifically mentioned) are gaining popularity for private pools, and I have received first-hand user reports that the salt /chlorination process seems very effective over periods of a year or more (although it is difficult to find real evaluation of these systems in the open literature).
However, in a public access pool, you have no control over who enters the water, and this is going to be the source of the most threatening public health issues. Cholera, giardia and cryptosporidium can be spread by people who evidence no physical signs of infection shedding spores into the water. Chlorine, even in large doses, is ineffective against these spores, but either UV or ozone can be effective.
The other source of giardia and crytosporidium is agricultural run off- i.e., if the river passes through an area where cattle or pigs are raised, or where manure is used as a fertilizer, it can carry the spores to the pool. Your filtration of 20 microns is not fine enough to eliminate these.
Cost wise, ozone and salt/chlorination appear about the same. UV would be the most cost-effective for a short term installation.
01/26/2011 6:52 AM
I have installed several pools without chlorine, but very good residual antibacterial potent. You must to change few technical inputs, and then users will give you best advertise you could get (no chlorine smell, no itching, no hair or swimming suits damage). Also, no any danger for swimmers lung (trichalomethanes, asthma etc). Electrolytically dissolved copper could cause and lead to green hair in swimmers, forget it. Ozone and UV are just great, but there are no long term action. Pool MUST have long term protection. UV destroy "active" chlorine in pool very quickly. So there must be added cyanurate. However, destroyed active chlorine, dont mean that pool water are free of chlorine. It is free from "active chlorine". Miroslav
CR4 Admin - email address removed
From the Site FAQ: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers posted in threads or comments, and we strongly urge you not to put up email addresses.
01/26/2011 7:12 AM
That sensitivity to the local environment is going to cost plenty.
There goes the Spanish economy.. of fear
..is all of the fuss to keep chlorine from being pumped back into the river when all is done?
01/26/2011 7:24 AM
Sodium Chlorite works well and has no known side effects.Derived from common salt and reduces back to salt. As for the dust, dirt and sediment there are lots of good suggestions already.
01/26/2011 8:03 AM
Filtration is NEVER enough to sanitize water against all potential organic contaminants.
I would highly suggest using either a copper/silver based sanitizer system and or an ozone system.
A quick search on the net will list many sources
01/26/2011 8:23 AM
Im JUST speaking from my personal experience. Filtration are very, very , very important, truly not enough. Sliver copper are good if know to use it, but slow action and could create several problems if you overuse it. 14,5 m3 are very easy to keep in perfect conditions without chlorine, and exchange water only once per season. Miroslav
Good Answers: 80
01/26/2011 9:41 AM
Try this link http://www.triogen.com/
They have all the UV and ozone equipment you will need for this pool.
The site also have some nice application notes that should answers all of your questions.
Good Answers: 18
01/26/2011 10:03 AM
This application is just crying out for someone with experience in party pools telling you to quickly do an internet search for your nearest local supplier of a biguanide system.
If you need to avoid the Halogens (chlorine and bromine based), then Hydrogen Peroxide is your new best friend. The salt-water systems generate chlorine inline before the filter at small levels, and result in a slightly-salty water to release into the wild when finished. They are effective, as it is basically a low-level, treat-the-portion going to the filter, chlorine system that oxidizes that side-stream flow of water before pumping it back to the pool. Either way, a once-nightly 'shocker' application would work for you, but lower pH of halo's leads to being harsh on skin and hair and you won't be able to hide the fact that the tell-tale Chlorine smell lets everyone know you used it...along with their blurry eyes and bleached hair :)
A biguanide is the same antiseptic-like biodegradable long polymer that is used to hose down veternarian clinics and clean surgeon's hands before surgery. You'll add typically few liters of your chosen biguanide "Bactericide" formula and a bottle of their matching algicide, per suppliers recommendations. First day and every few days after, you'll want to add around 2 liters of their brand of "Sanitizer" - basically a buffered Hydrogen Peroxide with some clarifier, which takes the place of the chlorine "shocker."
No odor, no harsh chemicals, totally biodegradable, no one will have any idea how you did it, and it works amazingly well.
It it totally compatible with either a sand-filter system or a dia-earth filter, and this type of water quality maintenance has another unique aspect: Use of H2O2 as the oxidizer each night actually enhances the operation of any UV/Ozone feature you may add to the filtration, and also enhances the anti-bacterial and anti-viral activity of any silver-containing component. Highly recommend you add both to your pumped filter assembly. If there is a chance of bathers dragging in fake grass, lots of wind-borne 'stuff', or other possibly floating debris that will head for the filter system, you 'may' wish to also put in a vortex sludge-removal prefilter that can be blown-down daily to keep that stuff out of your UV and sand filter tank.
The anti-bacterial activity is not reduced by sunlight, UV, or hot water, so unlike chlorine you will not have a problem in that desert environment during the day. It does not "explode" contaminents like halogens, but rather binds to them instead, so eventually the filter gets them. You'll want to add the Sanitizer at night, to maximize it's effectiveness during your event.
Yes, I've used this system - and after seeing it work on the job decided to use it for my pool at home as well. Now my wife won't ever let me go back to chemicals even if I wanted to. I've used the U.S. brands of Baquacil and SoftSwim as well as a generic equivalent. Any other issues you would have to deal with are long-term items irrelevant for a 10-day installation.
OH - and don't forget to throw in a floating LED light show fountain. The babes love those...and those floating LED balls too...and send us CR4'ers a link to the web photo gallery so we can pretend we enjoyed it too...
Call it 'half empty' or 'half full' if you must, I've got the other half in a redundant glass...
01/26/2011 11:51 AM
Wow, what a great response. Thanks to everyone who replied. I'll go through the responses that looked promising below, then post any new questions that have sprung up as I've read:
Tornado: I'm considering ultraviolet. It seems energy efficient and pretty simple. As far as I'm aware Ozone requires there to be chlorine in the water to function?
Leonf: I'm being lazy here by not doing some more research myself, but will chlorine really break down to become inert? How long does the process take? Theoretically I could close the pool at night and treat it with chlorine but it would need to be chlorine-free within a few hours of sun-up. The organisers are being quite firm about people swimming in any chemicals!
DVader1000 & mrclean: I will look into electrolysis and salt water filters :)
gcoffing: The idea is to keep the water chemical free if possible. I will look into aerators though as the water is likely to be pretty warm after a day in the sun.
waterparks: What makes you suggest a cartridge filter rather than a sand filter? The little bit I've learned so far suggested that the cartridges will clog with desert dust quite quickly and that a sand filter (either before or instead of a cartridge filter) would be better as it can be regularly flushed. Would love to know more. Maybe you know more than I do!
cwarner7_11: A very helpful post. Thank you! Ozone sounds more fiddly to get right and in a harsh environment I'd be concerned about errors or breakdowns that could potentially pollute the water or the air. This would not go down well with the organisers.
UV seems like a definite, especially as the presence of run-off in the river water is highly likely as it passes through cultivated land before reaching the desert. Am I right in thinking a carbon filter will neutralise any traces of pesticides?
marcot: Very helpful link. Triogen suggest that ozone systems don't perform well in smaller pools with high flow rate. I'm aiming for the highest flow rate achievable to counteract the dust that will be entering the water. That suggests that UV is definitely the way to go.
Sandman: Again, cheers for a helpful post. I'm hesitant with salt water generators as I'd be releasing 14 tons of sea water into the desert. Ideally I'd love (and the organisers have requested) that only river-quality fresh water go back into the water table. Admittedly, salt water better than a chemical cocktail so I'm not dismissing it. There is likely to be considerable dust going into the water, and possibly bits of costume. A vortex filter sounds an excellent idea, though would you say it was necessary with a flushable sand filter?
Looking up an LED fountain now - will be sure to post pictures up for you guys :D
NEW Questions:
Carbon filters - nobody has really mentioned these? Are they as useful at getting rid of contaminants as I've read or is the silence an indication that sand & cartridge filters + UV is sufficient?
Cheers to all!
Tass
Good Answers: 213
01/26/2011 12:13 PM
Carbon filters are very effective at removing all sorts of volatile contaminants (those that have noxious odors/tastes)- mostly organic compounds. One would have to look at the specific chemical composition of any pesticide/chemical fertilizer to determine if carbon filtration would be advantageous or overkill. Were we talking about drinking water, carbon filtration as the last stage before consumption is a standard practice for all of the potable water systems I spec...
Ozone does not require chlorine to work. EPA has documented the efficacy of ozone as a biocide, rating it as the most effective oxidizer available ("EPA Guidance Manual, Alternative Disinfectants and Oxidants", available for direct download by searching for the phrase "Alternative Disinfectants and Oxidants Guidance Manual - EPA 815-R". This document covers most commonly used disinfectant strategies, but does not discuss saltwater chlorination or ion exchange, if memory serves. This may also be a newer version than the one I have been using).
For your limited time frame, however, UV would most likely be far more cost effective. You do have to insure that the water has sufficient exposure time (a function of the flow rate).
Looking forward to the pictures...Be sure to include pictures of the mechanical installation (pumps, filters, etc)- some of us find that more invigorating than pictures of nearly naked women we can not touch...
01/28/2011 7:20 AM
Well a UV requires a filter size of 5-10 microns to be effective and since sand filter will only best give 20-25 microns Hence choice of the cartridge filter.
waterparks
Netherlands - Member - New Member
01/26/2011 4:19 PM
You may build-in a Ultra-Violet lamp in your filter system as well to ensure your water keeps clear during the 10 days of use. Such filter systems are generally used for ponds but I know they sometimes also use it for swimming-pools.
Best Regards, Herman Pieper
01/26/2011 8:11 PM
New info: Pool has been downsized to a 10 foot shallower pool holding 6500 ltrs as the cost involved in hauling 14 tons of water was just too great. This makes little difference as far as I can see, except to the flow rate. Based on your suggestions I'm working to the following spec:
Backwashable Sand Filter > 20 micron sediment filter > Carbon Filter > UV Filter
The flow rate is 6500ltrs/h (the entire pool)
Questions: I've been working on sourcing components for 6 hours now, trying to match the flow rates of the various different filters. This is proving a nightmare! How necessary is it to cycle the water fully every hour? I'm struggling to find filters with high enough flow rates. At the moment I'm looking at 9 carbon filters to meet the 108ltrs per min required rate, for example. With filter housings and pipework that works out pretty expensive. Would a 2h cycle time make a huge difference?
Are pleated 20 micron filters very much different to solid spun ones? I can get much better flow rates from the pleated ones but the difference is so great (2 pleated cartridges vs 14 spun ones) that I am suspicious about their effectiveness.
How does one moderate the pressure in a pool filter system? Again, differing filters require different pressures. Is it simply a case of moderating the pump pressure as best you can at the start, is it possible to change the pressure to specific filters?
You guys are amazing! Looking forward to showing you pics of the fruits of your labour. Now if any of you are in spain in July... ;)
Tass
01/26/2011 8:30 PM
This is a glorified hot tub at this point. I would think a two hp pump at full flow would be sufficient. One turnover per hour is very aggressive and requires oversized piping and multiple drains or skimmers to assure safety. You might end up with a vortex whirlpool. How far from the pool to the equipment? Gary
Good Answers: 213
01/26/2011 10:00 PM
Trying to filter the entire pool every hour is going to drive your costs through the roof. A complete change in four hours would most likely be excessive, but much easier to match equipment to the flow rate. There is most likely a health standard for public pools in Spain that can offer you guidance.
Good Answers: 48
01/27/2011 4:16 AM
The recommended cycle time when I was helping to rebuild the school pool some years ago was 3 hours. It was a 60 m3 pool, and we used the usual sand filter (massive & expensive, but effective & cheap to run) and a 2hp (I think) pump giving about 22-23 m3/hr flowrate. I was hoping to get away from chlorine, but alternatives at that time were either too expensive, or not acceptable to the wary school caretaker who would be maintaining the pool. I don't think you should be too concerned with the fineness of the filters. 20 micron sounds a bit excessive to me.
01/27/2011 7:44 AM
Thanks gcoffing cwarner7_11 and Holzfeller. Thats exactly what I wanted to hear. I was going on waterparks recommendation in post #7 but I think thats going to be beyond my finances. Apparently the recommended turnover for domestic pools is 6-12 hours, but that seems far too long to clear the dust from the water. I'm aiming for 3 hour now.
gcoffing: haha, my glorified hot-tub is actually 12ft. I measured it myself this time! The litre-age is correct though. The filter station will likely be mounted to a pallet and camoflaged right next to the pool
Holzfeller: 20 micron filters were recommended by a guy who built a pool at Burning Man festival in the Nevada desert, USA. Apparently desert dust is so fine it can pass through a sand filter.
Good Answers: 48
01/27/2011 8:33 AM
I can see the point of the 20 micron filters now. Desert dust is not a sight we see in this neck of the woods.
01/27/2011 8:05 AM
There are so many "i would like to..." opinions. Your pump must be in function minimum 8-9 h/day. DON'T even think to use active carbon filter (unless it is VERY necessary). You have create biofilm garden for microbes. Any who recommend it to you, are pool amateur. UV&the same are good on site disinfection (in the tube), bu water are unprotected in pool (from dust, swimmers etc). 20 microns are not too bad, bus 5 microns are better (but you need stronger pump). Sand, itself have not enough capacity to hold all pollutant's. You have good possibility, great chance, (as i see open door), but bad strategy. Good luck
04/29/2016 4:41 AM
I agree with #3. When you are still hesitate about which one to choose, Why not try Diatomaceous earth. It's completely biological and highly efficient.
Register to Reply 29 comments
bwire (1); chrusades (1); cwarner7_11 (3); DVader1000 (1); gcoffing (2); Holzfeller (2); hpi001 (1); jatawney (1); jcppfabric (1); JE in Chicago (1); kramarat (1); Leonf (1); marcot (1); miroslavbesermenji (3); mrclean (1); roy hammy (1); Sandman (1); tass (3); Tornado (1); waterparks (2)
