I have been considering using some stored carbon for purposes of family warmth in my home. My house has cathedral ceilings, so I have found high efficiency gas furnace to be an inefficient method of heating. I would like to have alternative heating at the ground level. This would reduce the chimney effect that the house has, I also know that just burning wood in a firebox is ascetically nice, yet yield a rather concentrated heat in the area.
I would like to heat water (not steam) and circulate it around my floor with PEX piping in a closed loop or modified circulating system to provide radiant floor heat. Anybody seen any vendors of said devices? I know the costs of these can be quite high if installed by a proffesional, so I am likely to try DIY. I need a simple and hopefully pleasing looking device. I do not need A huge BTU device like and external burner unit, rather about 50,000 BTU.
"A kite flies in resistance to the wind. Sometimes a little opposition can be constructive."
A certain amount of opposition is a great help to a man. Kites rise against, not with, the wind."--John Neal,
