I have participated in many bogs related to improving performance of IC engines. There is a need to improve burning and reduce carbon emission quickly through minimum changes to the engine.
The fuel (petrol or diesel or any other) burns in the presence of oxygen. Air to fuel ratio is very important. But are we assuming that within that the oxygen content is also constant in the air? For sure the the fuel used for aircraft is different as the oxygen content in the rarefied atmosphere is low. Similarly the oxygen content in rural areas, urban areas, thickly populated areas, winter / summer, and depending geography can vary. Moreover we have polluted air already. Is it better to inject a known amount of oxygen by fitting oxygen generator (may be oxygen cylinder or any other technique)- to mix with air while injecting fuel? Post-facto fitting catalytic converters etc may not help much, but definitely injecting oxygen will certainly help to improve power output as well in reducing carbon emissions into atmosphere. This may be a low cost, simple solution to the burning problem facing the world today.
