Hello Guys & Gals,
First, some background information:
I need some help from some of you electrical engineers guru's out there regarding the calculation of the electrical load for roof and gutter de-icing cables. I've been experiencing a lot of ice dam formations along my house roof eaves, gutters and gutter downspouts, resulting in some water penetration under our asphalt shingles and getting into the house that is resulting in some limited damage so far. It's been a cray winter here in upstate NY and we've now experienced no less than 9 snow and ice storms resulting in a layering effect of alternating ice and snow layers. I've removed most of snow and ice with a snow rake, used in combination with a water high pressure washer to try to break up the 8-inch thick ice dams atop of the eaves and rain gutters....a heck of a lot of backbreaking work......a real aerobic exercise regime!
I've already figured that I need to install at least 800 Lineal Feet of heating cables to cover all the eaves, rain gutters, and gutter downspouts. Of course I am going to install a automatic de-icer cable controllers (Temperature and moisture sensor type, UL and CSA listed). The cables I'm looking at to purchase are rated at 5 Watts per Linear Foot (some other manufacturers have 8 W/LF rated cables, but the cost is prohibitive). Also, since I've got so many runs of these cables I know that I'll need to install tee junctions and inline splices (available in kit form) or install several waterproof junction boxes for branch lines. I will also be installing a GFI and shut off switch in a exterior wall-mounted waterproof enclosure. Except the new circuit breaker, shutoff switch and GFI work which will be installed by a Licensed Electrician, I will be installing the heating cables and the controller units.
What I need help with:
Since I'm not an Electrical Engineer & my EE calculation skills are so rusty (actually crappy is what comes to mind...too many years since college electrical courses!). I need some expert assistance calculating the required electrical service cable between the circuit breaker panel and the automatic controller units.....per NEC Standard I need help in determining the type of cable and conductor size please. It'll be mostly attached to exterior wall siding except when it is installed down in the basement along the ceiling joists on its run from the circuit breaker panel inside a metal electrical conduit.....just to double check my Electrician's work.
Additionally, since I'm going to draw 4,000W of power (conservative at this moment and may actually be less), what size Circuit Breaker (Amperage) is required to be installed for this work? There's plenty of vacant room in the panel to install this breaker. The Voltage will be standard 120 VAC. I do have 220 VAC Grid service coming into the panel. Additionally FYI, I have a year old 7.56 kW DC Solar PV system with 2 Inverters, DC meter, and shuts offs which is tied into the same circuit breaker panel if that matters any...my guess is that it is probably not. The main Grid meter was installed by the power company and is the reverse-metering type.
Can you provide a sample calculation and/or NEC reference on how the new circuit breaker size was determined?
Thanks in advance for any assistance and suggestions that you can provide, and please have a great day!
