Previous in Forum: Storage Tank Stairs Design   Next in Forum: Cooling Strategies For Cryogenic Machining From Materials Viewpoint
12 comments
Help Identify the Steam Trap
02/04/2011 9:00 AM
Can anyone help identify this steam trap. We have received the picture from a customer whose factory is in the middle of the bush and he needs spare parts for this.
Please help as we are stuck.
Well, I've got to get back to work. When I stop rowing, the slave ship just goes in circles
Pathfinder Tags: steam trap
Re: Help Identify the Steam Trap
02/04/2011 10:44 AM
Good Answers: 61
02/04/2011 10:44 AM
Look Here:
http://www.iklimnet.com/expert_hvac/Ball_float_steam_trap.html
It might be a variation of one of these.
Do it once and do it right
02/04/2011 12:54 PM
Are there any letters or numbers in the casting?
02/04/2011 3:22 PM
You can also try this
www.spiraxsarco.com
02/04/2011 3:26 PM
It is clearly a ball float / thermostatic steam trap that I know but I have never seen one with 2 inlets and 2 outlets. There are no markings on it so I am a bit in the dark.
Good Answers: 61
02/04/2011 4:27 PM
Wait a minute!
"2 inlets and 2 outlets."
This may not be a "Stream Trap at all. It may be some sort of a
Heat Exchanger" possibly a Graham Heliflow or equal.
http://www.pess1.com/pdfs/graham_heliflow_heat_exchan.pdf
Engineering Fields - Piping Design Engineering - New Member Engineering Fields - Mechanical Engineering - New Member
Good Answers: 27
02/07/2011 12:32 PM
I think that Penn is correct. If this were a "pressure powered pump" as some suggest that it might be, it would have a smaller diameter motive pressure line as well as a vent/balance line fitting at the top of the casting. It clearly hasn't and hence, it's unlikely that this is a PPP. My bet is on it being a HX.
OP: If you're still stuck, ask your customer for more pictures taken from different perspectives and, have him provide you with the name plate data! Nobody can be expected to quote a repair kit for an unknown item. Even if you knew what it is, there may be various models of this item. Without specifics, you could provide a component which doesn't fit and the customer would probably expect you to take it back at your cost
Best regards, HeviiGuy
Good Answers: 203
02/04/2011 11:57 PM
Yes it is a float/thermostatic steam trap. It appears to have 3 (somewhat fuzzy) connections not 4. If it is truly 3 and not an elbow hidden behind something else it is probably an inlet, an outlet and a drain. Drains are often piped in if there is a persistent problem with the piping, the trap or some other unit in the piping circuit. it is much easier to open a valve to drain the system, let off pressure, etc. than it is to break a union or cut the piping. Often done after you have had one of these have a problem and you had to remove the drain plug while there was hot condensate within the trap. All it takes is one burn to convince you that you never want to have to do it again!
Good Luck, old salt
02/04/2011 3:51 PM
Could it be a steam driven pump I have installed these before and they look like a large F&T trap, if memory serves me?
Good Answers: 12
02/05/2011 11:54 AM
Its a steam auto pump trap , It works as an ordinary float steam trap integrated with steam pump.
here is all details
http://www.spiraxsarco.com/pdfs/SB/p612_01.pdf
don't tell me who are you , what do you know is enough.
02/05/2011 12:18 PM
Double inlet/double outlet F&T trap is applicable to all type of steam heating systems and steam process equipment where straight through piping is required. This would be the best start to repair or replacement.
Good Answers: 12
02/05/2011 2:30 PM
for More details including maintenance and spare parts ,look here
http://www.spiraxsarco.com/pdfs/im/p612_18.pdf
Register to Reply 12 comments
Anonymous Poster (1); BoltIntegrity (1); khairy Aish (2); old salt (1); PennPiper (2); philroth2252 (1); pipeit (2); Steam (1); Tornado (1)
