Previous in Forum: How a Fish Hook is Made?   Next in Forum: Ramp Up Model
Need Help for My Project
03/03/2011 12:52 PM
i am doing project on bearing cup wat i need is how much force is required for each stage (i.e forging sequence) and how much depth it will travel for each punch force please help
Project description:
bearing cup:
material :1045 steel cold drawn
final component : OD=20mm of depth 20mm and inner dia of 14mm and depth of 14mm actually this cup is done by impact extrusion and volume of the component is 4099mm3 and i calculated backward extrusion force=400KN
initial billet:OD=20mm and height 13mm here the press used is knuckle joint press of 650ton capacity
Engineering Fields - Manufacturing Engineering - Hobbies - Musician - Engineering Fields - Mechanical Engineering - Popular Science - Weaponology -
Good Answers: 39
Re: Need Help for My Project
03/03/2011 10:06 PM
This is your first post, so you don't understand. But, we don't do your homework or basic engineering calculations for you.
Hit the books.
Good luck.
03/04/2011 12:06 AM
sir please help i want to show this to my project guide its urgent
Engineering Fields - Electrical Engineering - New Member Engineering Fields - Mechanical Engineering - New Member
03/07/2011 12:06 AM
Did you already read a book ?, reading a book is gonna kill you
One system
Register to Reply 3 comments
gskssit (1); loadshare (1); Out of Box Experience (1)
