Previous in Forum: Electrolysis Corrosion (NOT FOR HHO!)   Next in Forum: Is Nitrogen Clean gas
Head Calculation
04/14/2011 4:52 AM
Dear sir,
I have calculated friction loss in 800m long 80NB FRV pipe with flow of 40m3/hr having 1100kg/m3 density & viscosity 10cp.
The loss comes around 65m.
I am in doubt that it seems high please advise me is it correct.
Guide me to get accurated result.
Thanks & Regards
Santosh
Re: Head calculation
04/14/2011 6:43 AM
i think it is correct:
Assumption: nominal diameter (ND) is confused with internal diameter (ID)internal , relative roughness=0.004; smooth pipe.
1/ case ND=3"=76.2 mm ***v=2.437m/s ***Re=20432 ***Moody factor=0.0335*** Result loss=106m.
2/case ND=3"1/2=88.9 mm ***v=1.79m/s ***Re=17513 ***Moody factor=0.034 *** Result loss=50m.
Good Answers: 1693
Re: Head Calculation
04/14/2011 3:29 PM
If in doubt, just go to one of the many free calculators on line, such as, but not limited to:Head Loss Calculator - Reef Central Online Community
Register to Reply 2 comments
You might be interested in: Spray Valves, Rheometers, Viscometers
