Hello all,
I will try to describe my question as it is possible
I m working on a mini project my project is
"Speed control and position control of A DC motor using PID controller"
In order to design PID controller I need the transfer function of the DC motor which i am using in my project.
the transfer function of DC motor is based on 2 things
1) Voltage to Rpm ratio i.e K
2) Time constant(tau) of DC motor
well i have calculated Voltage to Rpm ratio with the help of tachometer
what i need is Time constant, the problem is time constant of DC motor is very small because it has small inertia so I want to calculate the time constant
can any one of you tell me how i can calculate Time constant of D.C motor i m using
please provide the electric circuit by which time constant can be found and the whole procedure to calculate time constant using that electric circuit
Thanks
Waiting for your reply
