Previous in Forum: How Can I Measure the Centrifugal Force in an Electric Motor Rotor?   Next in Forum: Pole Mounting of Transformers
Good Answers: 61
IEEE Standard Block Diagram for a Generator Governor
05/19/2011 5:51 PM
As part of an interconnection study for a regional transmission operator (RTO) I have been asked to provide IEEE standard block diagrams of the excitation systems and governor systems on several existing synchronous generators. IEEE Std 421.5 details standard block diagrams for excitation equipment. I have been unable to find a similar IEEE standard for governor systems.
Every RTO in North America requires these diagrams for their stability models, but the staff at the RTO's I am working with have been less than helpful in pointing me to the source documentation. If anyone can give me a reference for the "IEEE standard block diagrams" for generator governor systems I would be very grateful.
Re: IEEE Standard Block Diagram for a Generator Governor
05/19/2011 11:58 PM
This, and many other papers on the subject, are available at IEEE digital library, but you should subscribed to get it
http://ieeexplore.ieee.org/Xplore/login.jsp?url=http%3A%2F%2Fieeexplore.ieee.org%2Fiel5%2F9620%2F30397%2F01397561.pdf%3Farnumber%3D1397561&authDecision=-203
dont say it, write it
Good Answers: 61
05/23/2011 1:55 PM
The paper you recommend only provides direction on how to implement, in a specific application (SimuLink), a standard block diagram you already have, then transfer that model to another application (PSS/E). It does not give the standard block diagram itself.
What I'm seeking is a standard which provides a set of control system block diagrams which can be used to describe the response characteristics of turbine governors when the appropriate constants for a particular governor are provided. Below is an example of one standard IEEE block diagram for a generator excitation system.
IEEE standard 421.5 gives a series these block diagrams for various types of excitation systems. There should be a similar document with standard block diagrams for governors, but I have been unable to find it.
Engineering Fields - Power Engineering - Power Engineering Passion Engineering Fields - Electrical Engineering - Engineering Passion India - Member - New Member
05/25/2011 8:47 AM
Sure Answers Always
Good Answers: 61
05/25/2011 8:55 AM
Dear Vinu_Answers,
Thank you for your response. I have the IEEE 421.5 referenced in your link, which shows block diagrams for various types of excitation models. What I am unable to find is a similar standard showing block diagrams for speed governors.
Tony
05/25/2011 8:57 AM
Good Answers: 61
05/26/2011 7:00 PM
Le_Noble,
Although your link did not give me the final answer, it gave me enough correct terminology to perform an intelligent search. Using that information, I was able to locate the necessary IEEE committee report. I also found a paper with similar information for modeling combustion turbines.
Thank you and a hearty Good Answer to you!
Tony
05/26/2011 11:49 PM
OK,
Good luck
Register to Reply 7 comments
Le_Noble (3); pwr2thepeople (3); Vinu_Answers (1)
You might be interested in: Pillow Block Bearings, Terminal Blocks, Pulley Blocks
