Previous in Forum: Human Excrement into Artificial Beef Steak   Next in Forum: fire mechanism
10 comments
Durability Of Plastic
06/18/2011 12:10 AM
I have come across quite many products with plastic parts, after few year, the plastic parts become brittle and broke. These plastic parts broke even though they were not subject to load or harsh environement, no direct sunlight, no water wetting, no chemical exposure etc, just normal home environement.
Is this the nature of plastic? Do all plastic suffer from this problem?
What plastic material are good for long durability, i.e it does not become weaker as it age?
Sharing knowledge is one thing that defies basic arithmetic logic --- the more you share, the more you get!
Good Answers: 97
Re: Durability of plastic
06/18/2011 1:40 AM
The plastic components in household appliance was not designed or intended to last. but I do have a plastic record player and portable radio bought in about 1965 that is still in perfect condition.
Plastics are formulated for a specific purpose. ABS - Acrylonitrile Butadiene Styrene for example is a very durable (recyclable) plastic.
I saw some ABS boxes capable of withstanding the harsh environment in a mine with high temperatures at deep levels. Even a Methane explosion did not cause much damage.
As part of the advertisement the manufactures performed a 2m drop test and submerged it in water(with electronics inside).
Alternatively open your cars bonnet and inspect the plastic components. The relays in my 1991 Camry (with 380000 km on the clock) has not reached their half-life yet.
Re: Durability Of Plastic
06/18/2011 9:38 AM
In most new home construction, plastic boxes are used for electrical wiring devices. Plastic is used as a covering for electrical wires. Plastic is used for water, sewer and drains. Window frame systems are made of plastic. Even the wood used for framing, flooring and outdoor decks can be plastic; the right plastic for the right job.
Mr.Ron from South Ms.
Good Answers: 1693
06/18/2011 10:50 AM
Your question is too general in nature, and not well informed.
For every broken plastic part you can name, I'll name 10 that have survived their intended life cycle.
Some plastic parts may be used where they are not well suited, or under engineered for the intended function, but most do a fine job.
I've got a 1985 Chevy K5 Blazer with many plastic parts that still look and work like new. It has spent many years in the Arizona desert when it is 110°F outside.
06/19/2011 10:57 AM
Wow Lyn!
"For every broken plastic part you can name, I'll name 10 that have survived their intended life cycle"
... lame, absolutely lame.
biggiginthesky
Good Answers: 1693
06/19/2011 11:25 AM
Perhaps you can add some enlightenment to the topic, instead of empty criticism.
Good Answers: 52
06/18/2011 10:29 PM
You assume "not subject to load or harsh environement, no direct sunlight, no water wetting, no chemical exposure etc, just normal home environement".
Reflected or diffuse sunlight contains plenty of UV.
Fluorescent lamps emit plenty of UV.
Home environment provides aerosol insecticide sprays, detergents, other chemicals.
The detergents in most home cleaning chemicals can kick the tripe out of many plastics not chosen for ESCR (environmental stress cracking resistance). Intelligently and responsibly specified plastics can easily outlast you! Casually specified plastics may have quite a short domestic life.
Mark Bingham
Relativity PL
06/19/2011 12:26 AM
No, not all plastics, just most of them.
In my experience, the most long-lived plastic is Teflon. I have Teflon antenna insulators that have been in the sun, rain, wind, snow, etc. for 40 years and show no signs of degradation whatsoever. On the other hand, Teflon is soft, so it would be almost useless for making gears or similar parts.
Bakelite is also quite durable, but it is brittle. I have a 1951 soldering gun with a Bakelite case. I think I replaced its broken case somewhere in the 1970's. It still works, although a few pieces of the case are missing.
There are many newer plastics, such as Delrin, that will probably have longer lives, but they are relatively expensive, so aren't used in your $50 printer...
06/19/2011 8:27 AM
Most plastics include additives to stabilise them and improve plasticity. These leach with time, eg in old cars the additives in the PVC used for upholstery created a film on the inside of the windscreen. The upholstery cracked.
Polymer plastics revert to mers over time. The mers have different physical properties. The mer may be a gas or liquid, the polymer (final plastic) a solid. eg ethylene is a gas, polythene (polyethylene), where the ethylene has been linked under pressure and temperature into long chains, is a solid.
06/19/2011 9:15 AM
Hi
I live in Australia so degradation of plastic in sunlight is a constant problem here.
Generally a UV stabiliser is added, either Carbon Black (soot) for black plastic or Chromium Trioxide for white or light colour plastic. Soot is cheap, so black is normally used outside. Nylon requires moisture to be added after molding or it becomes very brittle.
Often cheap parts are made with regrind, which is the faulty parts or sprue from a previous molding made into pellets. Also recycled plastic is sometimes used for cheap parts with some degradation from its previous life and a bit of hit and miss in the moulding setup.
Plastic prices vary considerably with recycled at the bottom and some stable exotic plastics at the top.
http://www.protomold.com/DesignGuidelines_ResinGuide.aspx
The nice thing about Standards is there are so many to choose from.
06/20/2011 5:57 PM
Manufacturing processes are not perfect. I work in an industry in which thermoset vinyl is a big part of the business. Getting the correct ratio of plasticizer, pigment and the base vinyl is essential, as are curing time and temperature. It would be nice to be able to say that all these parameters are perfectly met for any given product, and quality control IS a big part of our business. But reality happens and products do occasionally get out the door which might have slight parameter discrepancies. And not everyone in the industry is as quality conscious as we hope that we are. So what you may be seeing might be partly quality control issues.
Register to Reply 10 comments
biggiginthesky (1); dkwarner (1); Hendrik (1); illya Leonov (1); lyn (2); Phaddy (1); Relativity PL (1); ronseto (1); Tonymech (1)
