Previous in Forum: CNC Machines With PCB / Case Modification In Mind   Next in Forum: Uses of 1 Ton Per Hour Capacity Ball Mill
Nitrile Rubber Sleeves Cutting
06/21/2011 1:33 PM
I need to cut nitrile rubber sleeves of od 70 mm and 85 mm diameter with a wall thickness of 2.2mm,3.5 mm etc on a lathe type small machine.The sleeve is held on the bore with a wooden mandrel which rotates.I am looking for suitable blades which will be fitted to the tool post and gives good result in terms of production and finish with 0.3 tolerance on thickness after cutting.
Re: Nitrile Rubber Sleeves Cutting
06/21/2011 1:49 PM
We use a tool that utilizes a box cutter blade with good results. See photos.
Canada - Member - New Member
Good Answers: 11
06/21/2011 11:54 PM
Smart tool!
Good Answers: 1693
06/21/2011 3:06 PM
In a pinch, I've c-clamped a hobby knife blade to the tool post.
Register to Reply 3 comments
dgibson (1); gigaconcept.com (1); lyn (1)
