I am trying to figure out the dimensions, pump sizes and specifications for a restaurant sewer pumping station. The station will/should pump up to 80m to the main man hole.
lets say the place has 5 toilets with 6l flusing cisterns and a restaurant/takeawy kitchen
i did a rough calculation and found the waste water inflow as 6.372m^3/hr, am now having trouble with the size of the of the tank and the sizes(capacity) of the pumps.
First, you need to obtain a few things first. We don't know where you are located in the world. That would help.
#1. Obtain a copy of the local or national building code that delineates the hydraulic loadings of each water using fixture. Knowing that will determine peak flows via known "fixture units".
#2. Obtain a good engineering textbook on the design of wastewater pumping stations. You can go visit to the Water Environment Federation (WEF) website and visit their bookstore to find their highly detailed book about designing pump stations. There are other textbooks available for free on the web, in the form of e-books, that deal with the subject. Do a Google Search.
#3. Obtain engineering/technical catalogs from several pump manufacturer's that include pump specifications, and pump performance curves.
If you have no prior experience designing a wastewater pumping station then you shouldn't have undertaken this adventure in engineering in the first place. My feeling is you're either a very green engineer or non-engineer.....leave it to the professionals who know what they're doing.
Lastly, we only give advice here. We do not solve your problems for you.
Hear, Hear....
To many folk think that a simple post will answer ALL their problems and its the easy way to get the job done with the least amount of brain power and money!!
