Previous in Forum: Current Capacity of al./cu. Strips   Next in Forum: Why The Middle Phase Excitation Current Always Lower On Transformer
UPS Neutral
07/15/2011 5:28 AM
Why UPS output panels require Double Nutral.
Kindly explain
Regards
Murali
Good Answers: 44
Re: UPS nutral
07/15/2011 11:36 AM
Two is better than one (cheaper and easier to work with). Harmonic "control".
Good Answers: 61
Re: UPS nutral
07/15/2011 6:28 PM
Non-linear loads cause harmonics in the power system. In 3-phase, 4-wire systems, the triplen harmonics (every 3rd odd multiple of the base frequency) are additive in the neutral connection. This causes excessive losses and heating of the neutral. By doubling the size of the neutral, the impedance (and therefore the losses and the heating) are reduced.
Emerson has a good explanation here.
India - Member - New Member
Good Answers: 164
Re: UPS nutral
07/15/2011 11:21 PM
GA to you, and thanks for the excellent link.
Good Answers: 169
Re: UPS Neutral
07/27/2011 9:46 AM
To carry the real "RMS" Neutral Current, which includes Triplen Harmonic Currents too, which accumulate in the Neutral, apart from the Fundamental Frequency Current. The true RMSNeutral Current can go as high as 200% of the phase current. And, any UPS is the main source of such triplen harmonic currents. Hence, the UPS Neutral is sized 200% (Double Neutral) so that it does not overheat even in the above situation.
Register to Reply 4 comments
cuba_pete (1); electricalexpert65 (1); kvsridhar (1); pwr2thepeople (1)
