Previous in Forum: Load   Next in Forum: Battery
13 comments
Laser Cutting of 0.15mm Thick Aluminum Foil - High Speed
08/31/2011 3:44 AM
Hi
Can anyone tell me if there is laser cutting technology that can be used on one of our machines
I would like to upgrade from mechanical to laser if possible
I need to cut over a distance of 450mm at a speed of 1000mm/sec
Aluminium foil is max 0.15mm in thickness and 0.08mm for other products
Is technology on planet earth there yet ?
we use a high speed circular blade at present
Winning begins in YOU !!... not around YOU :O)
Re: Laser cutting of 0.15mm thick aluminum foil -high speed
08/31/2011 3:47 AM
I think so. It can also be done with water jet or plasma.
08/31/2011 6:45 AM
I am all ears...where can I get quotes ...very keen on this
I am in South Africa, province of KwaZulu Natal
Thank you for your input, appreciated
Gavin
08/31/2011 8:13 AM
08/31/2011 8:55 AM
APPRECIATED .. Thank you
United Kingdom - Member - New Member China - Member - New Member
Re: Laser Cutting of 0.15mm Thick Aluminum Foil - High Speed
09/01/2011 3:29 AM
This does not sound that difficult to do.
Lasers that I have used in the past are from Preco Inc. and Trumpf. I am not sure if they have anything in South Africa but I am sure they would have a solution for what you need.
The only challange would be the speed you are needing. If what you are cutting is in reel form then the laser beam could be stationary and only turn on when the material feeds.
If you are requiring a cut across the feed direction of the material then the laser beam would need to move either by the cutting head moving or having deflecting mirrors. The deflecting mirrors would allow for a faster cut but would require additional components in the optic system.
Another thing to remember is that alluminium is quite reflective to lasers and could leave burring on the cut edge if no assist gasses are used. But I do not have experience cutting alluminium this thin. Most of what I have cut was 1mm-6mm thick alluminium and steel and various thicknesses of PET's.
09/01/2011 3:59 AM
Thank you so much Aarrus75.. appreciated
It is a cross-cut scenario and the head would have to traverse to and fro
I will most certianly be contacting Prefco Inc and Trumpf
Your input is treasured
Thanks
09/01/2011 4:16 AM
HI Eagle888
I have been using Preco lasers for about 15 years and have found the equipment and their support to always be excellent. The machines we use are mainly for PET and other thin material cutting.
Just be warned they are not cheap but they are reliable. We are still using systems that were purchased 10-15 years ago.
My experience with the Trumpf systems is a bit more limited to cutting thick metals.
09/01/2011 6:40 AM
Again, Thanks a million
WOW, this Forum is packed with amazing humanbeings
appreciated
Good Answers: 93
09/01/2011 4:20 AM
We have tried getting thin material (0.25-0.5mm) cut on a number of the commercial lasers & the cut is often quite rough compared to the thickness of material. We have had success using a UK company called Tannlin whose core market is cutting foil stencils for PCB masks. They also supply laser cutting systems, they don't mention the speed in their spec but the machines are optimised for cutting 0.02-1.0mm material. Might be worth dropping them an e-mail.
09/01/2011 7:35 AM
Thanks a million Nigh .... appreciated. Will get cracking straight away
09/01/2011 7:56 AM
Email done and dusted ...I eagerly await their response...hope they can service us here on the tip of Africa... East Coast...KwaZulu Natal...the last British outpost
Cheers
09/06/2011 3:42 AM
Tannlin are onto my project...samples being shipped to them to run trials
Thank you Nigh
Good Answers: 93
09/12/2011 5:06 AM
Glad to help, I found them very easy to talk to. Hope it works out for you.
Register to Reply 13 comments
Anonymous Poster (1); eagle888 (7); Nigh (2); Tornado (1); varrus75 (2)
