So I just got a back-up propeller for my paramotor, and the hole pattern it came with isn't correct. I'm going to pound in dowels with some epoxy and re-drill the holes, but I would like to see if anyone has a strong opinion on where I drill the new holes.
I can either offset the holes slightly inward of the existing ones (after plugging the current holes ) see pic
or
I can rotate them 30 degrees and center them between the old holes (will still plug the existing holes first)
see pic
There also may be a better solution than these two as well, but realistically, i'm not sure that it will make a huge difference in the end - as always, Thanks in advance for any constructive input
