The approach is 2 generators, facility power and a redundant UPS. The boundary conditions are:
1) 208/120 60 Hz critical power to a command and control center (possibly 50Hz-more on that later)
2) facility power is 415/240 50 Hz
3) System(s) to be sheltered in a narrow 40' ISO container (modified/cut as needed for doors, HVAC, etc)
4) estimated critical load 161 KVA (maybe less-as other players suggest otherwise)
With a redundant UPS, one would think that critical power/reliability is all taken care of. Derived design constraints become:
-UPS does frequency conversion (thus bypass is not viable if 60 Hz is the load requirement)
-use transformer to get either facility power or UPS output down to 208/120 (throws a redundant transformer question into the equation (keyed switches, etc)
Next challenge is too many engineers with a hand in the design with requirements/questions such as:
-research closed transition ATS (not need UPS?).
-want bypass (in case UPS [and redundant UPS]) fails (50 Hz to C2 center???)
-growth (scalable UPS)
What statistical foot can I stand on to stop the design reliability configuration insanity? The "what ifs" are just too many to cover. Is a belt, rope and suspenders needed?
