Previous in Forum: Making a Four-Stroke Engine   Next in Forum: Using FET as Low Battery Cutoff
Dependable Energy
10/08/2011 2:11 AM
What is the definition of dependable energy in hydropower sector. It is a kind of energy as average annual energy or firm energy?
Pathfinder Tags: Energy hydropower
Re: Dependable energy
10/08/2011 2:33 AM
Hmmm - The definition of dependable energy - ahhhhhh
Pumped storage wind, solar, and tidal?
Reliable fixed cost, absolutely no geo-political risk or hidden costs.
Talk about dependable!!! Put pumped storage into the green energy equation and that "dependability/reliability" issue goes away.
All of a sudden there is no need to continue with the " ain't gonna let clean water and air interfere with makin money" mentality.
Gavilan
10/08/2011 4:27 AM
i think it might be judged by the worst weather conditions over a certain number of years, 50 years perhaps.
Good Answers: 97
10/08/2011 5:09 AM
That would be the energy that can be dependent on without exceeding the limited flow/volume during drought situations.
The output should be increased during good years.
For practical reasons the definition should be refined to only cater for say 80 to 90 % of the time and shortages supplemented by other means.
Good Answers: 67
10/08/2011 5:33 AM
It may be useful article for this subject.
europa.agu.org/?uri=/journals/wr/97WR01713.xml&view
Dependable Energy capacity of a system of a hydropower facility is the load-carrying ability of the system under adverse conditions (Corpes of Engineers Hydropower Manual, 1985).
Dependable Energy is not an average annual energy.
Re: Dependable Energy
10/08/2011 11:02 AM
Coastal Pumped Storage could use the ocean as the lower reservoir. No water supply problem there.
Inland - unless the upper and lower reservoirs are used for irrigation or water supply the stream flows only need to support evaporation and seepage rates.
Gavilan
durtieduck (1); Gavilan (2); Hendrik (1); pritam (1)
