I have a SANGEAN ATS 505 portable. It has both AM and FM reception (c/w multi-bands). The FM has the typical collapsing movable antenna and also a jack input suitable for plugging an extension antenna setup. A simple friction extension can also be attached to the external antenna. I can get good FM reception of local FM stations.
I live in a fairly remote area amongst bush and hills.
My problem is with the AM reception. I can pick up a couple of the local national stations fairly well. The radio has the normal inbuilt ferrite rod but no means of plugging in an external AM antenna. If we chose to listen to a different station from the two strongly transmitted ones, I usually get the fade-outs that occur at around sunset etc, and have a very unstable reception most of the time.
I have posed the question from time to time, as to how I might be able to improve the reception of the AM stations. I have had suggestions that include putting the radio in a box (cumbersome) that has a tunable external antenna so as to try to fine-tune the signals picked up by the internal antenna.
Has anyone got any reasonable suggestions as to possible arrangements?
