I have inquiry regarding ball valve seat, in our developing tool prototype we
have a 3way ball valve of 2" bore , the tool is exposed to high
temperature up to 350degf, while nominal operating temp is 300degf. The seal
will see a differential pressure from low as 300 psi , and in critical times up
to 3000psi. The valve operation requires low torque seals (soft seats).type of
medium to be Mud (less than 1% sand).
Plz advise on what is the minimum thickness (dimensions) for the seat!!? And what do u recommend for the seat material that suites the design parameters.!?
Any material to help on how to design valve seat in terms of dimensions boundaries.!
Regards,
Thank u
