Previous in Forum: Changing Antifreeze   Next in Forum: Porocity Control of Lead
Ph of Absorption Reagent
12/21/2011 2:37 AM
hi gm my que. is - what is the Ph of a absorption reagent?
Pathfinder Tags: chemistry
Re: chemical
12/21/2011 2:59 AM
It depends on what the absorption reagent is, which could be all over the map.
While you're at it, please ditch the dopey textspeak, and spell pH correctly.
Re: chemical
12/21/2011 3:48 AM
It would rather depend on what it is, and its concentration.
Good Answers: 101
Re: Ph of Absorption Reagent
12/22/2011 7:43 AM
Depends upon what chemical it is obviously. You use alkalis to absorb acids and vice versa.
Register to Reply 3 comments
DVader1000 (1); PWSlack (1); Tornado (1)
