here are many types of
aluminium castings that are used in the various industries now a
days. Depending on the need of the aluminium castings, the method of
casting is decided. There are however many companies that specialize
in only one particular way of the mold casting method like Endurance,
who is one of the leading aluminium die casting
firm One interesting thing that about aluminium casting is
that during the invention of this method, aluminium was not the first
choice for the making of castings. Fragile metals like tin and lead
were used at that time. However after the discovery of aluminium, no
one went again to use lead and tin again!
Commonly Used
Aluminium Molds
The following mentioned
are some of the commonly used processes that are used for the process
of aluminium casting. Different types of molds are needed in today's
industries. These molds are broadly categorized into two categories,
temporary mold and permanent mold.
- Die Casting:
Aluminium die casting is one of the widely used methods of aluminium
casting, especially in large industries wherein many castings are
required. Aluminium die casting method is generally used in
automobile, aerospace and power tool industries. In the process of
die casting, aluminium or other molten metal is forced into the
molds under high pressure. There are four sub-types of die casting
method viz. low-pressure die casting, vacuum die casting, squeeze
die casting and semi-solid die casting. Each type of the method
works according to its name.
- Permanent Casting:
These types of molds are made from steel or iron. Permanent
aluminium mold castings are quite cheap and hence are used in
industries where large number of casting are required. Gravity or
vacuum is used to cast molten metal into the mold.
- Sand Casting: This
is one of the oldest methods that have been used for aluminium
casting. As the name suggests, sand casting method is used for
making sand moulds only. The created sand moulds can re-used, this
method is in fact used for making permanent patterns only. Aluminium
sand casting has been used since the Egyptian times, the purpose
however has changed. Today the same is used for making manifolds,
blocks and other heavy castings for engines. The method of creating
a sand casting mold is very interesting. For creating a sand cast
mold, a cavity is made in the sand and held in a box.
- Plaster Casting:
This type of mold is made by the baking method. Pour plaster slurry
around wax (even foam will do) then bake it. By doing so, the
pattern will melt which will leave give you the desired shape. You
can then pour the molten metal in any of the plaster molds.
- Shell Casting: Shell
castings are used for producing castings with accurate dimension.
Unlike permanent casting method, shell casting method is quite
expensive and hence is not used on a large scale.
These were some of the
commonly used molds for aluminium castings. Of the above mentioned
methods, aluminium die casting method is one of the most complex
methods. So do make sure to buy your aluminium castings from a
reliable Aluminium
Die Casting Manufacturer only.
