Hello,
I have just cannibalized an old Philips T581 washing machine for parts, including its motor. It appears to be an Ardo make (Slovakian) with the following specs:
220v; 50 Hz
2Pol 2800/min 2.4 A
16 Pol 300/min 1.6 A
There are two Live, two Earth and two Neutral wires coming out of the motor.
What I can't find on the net is whether this motor is suitable for generating electricity, either through making a wind turbine or other means (e.g. with a bicycle).
Can you help? It would be useful to know the following:
- if it would generate AC or DC current
- does the inside need re-wiring?
- how to wire up correctly the six wires coming out of the motor to a light-bulb.
Many thanks.
Steve
