Previous in Forum: ANSI Leakage Spec and Calculation   Next in Forum: How Can I Amplify My Hydraulic Pressure?
10 comments
Diesel Engine
01/24/2012 11:29 AM
Diesel engine breather smoking lot but crankcase oil level no losing , what is the reason
Re: Diesel engine
01/24/2012 11:32 AM
Damaged/broken piston rings?
Re: Diesel engine
01/24/2012 12:30 PM
Thanks buddy
Re: Diesel engine
01/24/2012 11:39 AM
Re: Diesel engine
01/24/2012 11:57 AM
High running hours and worn out.
Re: Diesel engine
01/24/2012 12:32 PM
Thank you guys
Good Answers: 16
Re: Diesel engine
01/24/2012 8:13 PM
As PWSlack suggested broken rings and others have mentioned possibly high hours, ok these are some instances, but we could go much further by knowing what you engine is exactly. Two or four stroke, Mfg, model, hp/kw rating, application?
Re: Diesel engine
01/25/2012 3:43 AM
When did the telephone call go in to the engine's manufacturer, what was the response and why has it been devalued sufficiently to warrant a posting in an international anonymous Engineering internet forum?
Good Answers: 16
Re: Diesel engine
01/25/2012 4:06 AM
He may not have liked the answer he got from them and looking for a magic fix that can be downloaded
Re: Diesel engine
01/27/2012 11:18 AM
Is this engine recently overhauled? or is it due for overhaul? In case of new rings some times lot of smoke comes from the breather till rings sets in. In case of partial damaged rings also lot of smoke comes without loss of oil.
Re: Diesel engine
06/20/2012 12:59 PM
Thanks for all buddies
Register to Reply 10 comments
Mukesh0861 (1); Narayanasamy (3); PWSlack (2); SolarEagle (1); tcmtech (1); Tim in Mexico (2)
