We are looking to replace an old (1959) 1000hp motor with a newer motor of the same horsepower. The old motor is of the pedistal bearing type with a 9 inch shaft running at 394 rpm on 4160 volt. A typical over-built steel mill motor. We are looking at newer packaged frame motors and are a little concerned with the difference in size and robustness. (is there such a word?). I have been working with these motors for the past 25 years and I know that there is some difference with "old" verses "new". The torque curve might peak later, is the "new" 1000hp the same as the "old" 1000hp...etc. I am looking for some insight from someone who has done something like this before and might have some words of wisdom that I may not have thought of yet. BTW the loading on the existing motor is about 750hp at a 30% duty cycle. 5 seconds loaded and 10 seconds idling.
Thanks in advance,
Jim
