Dear all,
An unfinished project, with a big accumulated delay, fell in my table one month ago.
Here I am with my wife, in South Sulawesi, (sorry for you, snow covered poor souls... unless you can not stand the mosquitos and the continuous 28ºC!!) for the next 3-4 months.
As part of the "what we have here, really?" initial investigation, It was found that there were 12 hydraulic cylinders (iD 450mm, rod D150, L1600, operating pressure 110bar).
They were depreserved (does exist this word?) and connected to the hydraulic circuit around 10 months ago. And no flushing (with following filling of the oil circuit and reservoirs) was done yet.
Using an endoscope in the cylinders, it was found...Mars...
(Sorry for the quality of the pictures)
So, one of the cylinders (the worst looking one) will be taken to the factory workshop, to be opened, assess the extension and severity of the corrosion (I do not expect much, or better expresed, I hope do not much), and decide the next steps.
This as per customer desires. I know they all require to be removed, (already informed in written to the customer, but customer is not able to eat this pill).
Now, the cleaning of the cylinders.
1st. Check the workshop ensuring it is clean enough for the work to be carried out (No big hopes on that, tomorrow I will see)
2nd. Set a sniper on top of the workbench at repair workshop, with direct orders to kill (or at least injure severely, knee shot) to anyone approaching the area with sandpaper and a smile. The smile is more dangerous because means he thinks himself that it is a "good idea" , and is not simply following orders.
3rd. Shout around to dismiss unwanted and "savvy" spectators (or give to each one a broomstick, this scares them the most!!)
4th. Disassembly
5th. Use soft metal brushes and oil to clean the rust.
6th. If no signs of pitting, reassembly and fill with properly clean oil (NAS8 min.)
7th. Set in position again, and do not open/reconnect to the circuit till this one is absolutely clean and ready to be filled with oil.
8th. Order several sets of spare seals in advance.
Three questions:
a. Some other point to have in acoount that I have missed, or comments on the listed ones?
b. Apart of the brush-oil method, do you know (by experience) of some other rust removal system/product?
c. The piping system requires a good cleaning and pickling, prior to flushing.
Do you know how much pickling affects to wall thickness in CS pipes?
I am using Ermeto pipes with 4mm wall thickness.
Salu2 and many thanks for your time and help.
Abel
