Previous in Forum: CL 300 vs CL 600 Flanges   Next in Forum: Water Sweating For Airlines
45 comments
Pump Suction Line Reducer
02/05/2012 8:15 AM
Hi all,
I need one clarification regarding pump suction line reducer.
Is it the reducer compulsory required in the pump (centrifugal) suction line? The line size and the suction nozzle for the pump is same. Please explain.
Good Answers: 1693
Re: sunil
02/05/2012 8:18 AM
No.
No.
Re: sunil
02/05/2012 8:55 AM
what does it mean?
Good Answers: 1693
Re: sunil
02/05/2012 9:03 AM
Good Answers: 137
Re: Sunil
02/05/2012 9:39 AM
Presumably somebody has done some work and decided that suction pipe dia = to pump suction connection is OK (this isn't always the case). In that case it's not easy to fit a reducer
Re: Sunil
02/05/2012 10:25 AM
In many cases, especially if the suction piping is long, it may need to be larger than the pump connection. In such cases a reducer is required. In most instances it should be an eccentric reducer with the top flat, but there are possible exceptions.
As already mentioned, if it has been satisfactorily determined that suction piping of the same size as the pump connection is adequate, then no reducer is required.
Re: Sunil
02/05/2012 11:30 PM
Does the choice of concentric or eccentric reducer depend on suction conditions(positive or negative),velocity of flow at suction or some other factors?.
pnaban
Good Answers: 97
Re: Sunil
02/06/2012 12:18 AM
The concentric is to prevent bubbles of different densities stuck/dam before the eye of the pump.
For normal water - air it must be flat at top.
Good Answers: 97
Re: Sunil
02/06/2012 8:49 AM
Oops - finger error - it should have been eccentric
Re: Sunil
02/06/2012 1:33 AM
I have never heard of a concentric reducer being recommended in a horizontal pump suction line, but there might be some possible exceptions.
Re: Sunil
02/06/2012 2:26 AM
We used concentric reducers in horizontal suction pumps in Saudi Arabia with KSB(German)Pumps but eccentric reducers were used if suction was negative to prevent air trapping.
pnaban
Re: Sunil
02/06/2012 2:35 AM
That sounds unusual, but if it works, it's okay.
Good Answers: 179
Re: Sunil
02/05/2012 11:39 AM
Tornado is absolutely correct in regard to his sound advice.
He's earned a GA from me.....
Re: Sunil
02/05/2012 11:42 AM
Reducer is not compulsary but it helps in increasing suction velocity of the fluid coming from the bigger dia line and thus improves the suction conditions.
Good Answers: 203
Re: Pump Suction Line Reducer
02/05/2012 10:50 PM
If it is an existing installation and has been operating fine then it is OK. Depending upon the material being pumped and the volume being pumped it quite often cheaper and more expedient to go with a pump of the same size as the inlet piping than to invest in the additional fittings and labor to use a smaller pump. This is not a universal solution but if it works DON'T FIX IT!
This explanation is usually applicable to smaller pumps and not larger ones. This is not intended as an all inclusive answer that fits all applications.
Good Luck, Old Salt
02/05/2012 11:04 PM
Pumps suction piping are generally kept at larger diameter than pump nozzle size to reduce frictional losses which are dependent on the fluid velocity in the suction piping. But if it happens to be of the same size as suction nozzle then you cannot put a reducer. Just ensure that you have enough NPSHA for the pump to operate with out cavitating.
02/06/2012 6:57 AM
Once for a duplex water booster set our Sales Engineer selected a common suction line with footvalve and pumps couldn't suck. Later we fitted two separate smaller suction lines and pumps were working properly. The reason was the dia of common suction was too large for a single pump but OK for both pumps sucking together.
pnaban
02/06/2012 12:13 PM
I have to agree with gsbasha, instead of reducing the suction side most people need to put a valve in the discharge side and throttle the discharge and prevent cavitation.
02/05/2012 11:44 PM
Hi Sunil,
The fluid velocities in suction header are normally very low ..Approx. of the Order of 1 mtr / Sec. So before concluding anything, it is advisable to calculate the theoritical velocity in the suction header.
Next step would be to estimate the pipe losses in the suction side . You must try to keep it low and arrive at a most suitable suction header size.
Since the Pump suction size is already fixed by the pump model selected for the application, use a Eccentric reducer with Flat side on top as suggested by Tornado, if there is a size difference. The reason is to prevent air from trapping inside.
Hope it helps.
02/06/2012 1:57 AM
The purpose of the reducer is to avoid collection of air in the suction line and thereby obstruct the flow . I have seen it in all horizontal pumps.
02/06/2012 2:44 AM
hi Irshad,
Pls see the images
please advice
sunil
Location: I come from the deep south but currently reside in the land of ice and snow, midnight sun and all that crap
02/06/2012 4:14 AM
Good answers but one consideration.
As several people have pointed out, the suction line is typically sized larger than the pump suction to provide a small loss on the suction side of the pump so you have adequate NPSHa but the orientation of the reducer depends on the service.
If you have water (or some other clear liquid) you need to put the flat side of the eccentric reducer on top but if you are pumping a slurry you should put the flat side on the bottom to prevent the solids from accumulating and possible plugging the suction line.
02/06/2012 4:16 AM
What fluid, at what temperature and pressure?
There must be the correct conditions at the inlet of the pump, otherwise cavitation and pump damage will ensue.
02/06/2012 4:52 AM
HI,
I thing all the details i have provided
fluid = water
pressure and temperature mentioned in the images
sunil
Good Answers: 67
02/07/2012 11:21 PM
Here suction pressure you gave 6.5 barg but design data for pump at #17 it is 0 psig with differential head of 45 m. So please check whether pump seals are properly designed for 6.5 barg suction pressure. You have not commented question from many members about orientation of the pump, horizontal or vertical and pump is installed or yet to be installed. The engineering firm who has designed piping cofiguration and sizing should be questiond whether suction velocity (appears to be high) is considered as per relevant standards while deciding the suction pipe size.
02/06/2012 4:56 AM
hi,
pumping temperature is 28 deg c reated
52 deg c max temp
28 deg c norm
12 deg c min
sunil
02/06/2012 5:24 AM
OK. Nothing too arduous.
Now, what is the size of the pump inlet and what is the size of the pipe that it is to be connected to?
Here we are 20-odd posts in, and the full information about this installation is still being uncovered....
02/06/2012 6:03 AM
hi,
pump suction nozzle size is 8" dia
and the lline size is also 8"
sunil
02/06/2012 8:48 AM
Then there's no scope to install a reducer!
<mutter, mutter...>
02/06/2012 8:50 AM
Your line size is 8 inch and pump suction is also 8 inch then where is need of reducer? and why this question was raised? Do you face some problem in your pump?
02/06/2012 9:19 AM
It is unlikely the problem is to be found in the pump....
02/06/2012 9:28 AM
hi,
Appreciate the comments but, who will see the suction velocity, cavitation & air bubbles
what will be the pump performance sue to this
can u give me the guarantee pump life.
i am not a fool to ask u
sunil
02/06/2012 9:34 AM
The pump manufacturer should be approached for commercial warranty issues.
If the suction line is inappropriately sized, then everyone will see cavitation!
Good Answers: 130
02/06/2012 7:17 PM
"cavitation" is always due to lack of feed volume inducing a vacuum.
It sounds to me what you need is a 10 or 12" line, or you need to pressurize the the feed reservoir. Or as mentioned, throttle the output.
Then, if you went for a larger line, you would put in a reducer to 8" at the pump so the things join up.
02/06/2012 11:17 PM
GA, with a possible addition. Many pump manufacturers recommend a straight piece of pipe, length 6 x pipe diameter, with no fittings, entering the pump suction. On this basis, any reducer would be a short distance from the pump rather than attached directly.
Good Answers: 130
02/07/2012 12:45 AM
Good point. GA back at you.
Turbulence and/or a large velocity gradient, right at the intake, is not preferred.
Also meaning any bends involved should be in the (even) larger feed line, not in the intake run.
02/07/2012 7:05 AM
Will you quote from any manufacturer as well as its name?. Is it for a particular type of pump or in general to all types of pumps?.In saudi arabia we installed reducer directly to suction and discharge flanges. The sales engineers never calculated NSPH but referred some charts or tables.For flow meters I have heard that there should be a minimum length(xD) of pipe without fittings on either side.We get knowledge from many sources like text books,Engineer's reference/hand books, manufacturer's catalog,codes/standards,own experience, experienced people in work places as well as from Engineer's forum. Do they contradict with each other?.
pnaban
02/08/2012 5:32 AM
All centrifugal pumps.
Good Answers: 137
02/07/2012 2:43 PM
He's already told us in #20 that the suction pressure is a massive 6.5 barg.
Suction velocity is about 2.5 m/s, depending on pipe schedule, which might be a bit brisk if the suction system were marginal, but with 6.5barg at the pump it's OK.
I've known of multi-stage pumps for seawater injection for secondary recovery on oil platforms, typically 2500kW with 200bar ΔP, and they only needed a suction pressure of 5barg, provided by an "ordinary" centrif. 4.4bar ΔP here is hardly in that league!
02/15/2012 4:06 AM
You are feeding data and then asking guarantee for the pump performance ???
Many contributers have suggested to put all the details in one go so that appropriate suggestions can be contributed. You said that you are not fool to ask the question, but contributors can suggest based on you data, your main line is of 8 inch and pump suction is also of 8 inch dia then where you are suggesting to put the reducer. I may not be understanding your requirement, but as the subject is broad, and replies can be in particular direction, you should come up to put the exact problem in the forum with all the details available.
Good luck.
Good Answers: 137
02/06/2012 4:57 PM
As you've given a figure for NPSHA, suction line losses must have been calculated. With 76.1m NPSHA it's most unlikely there will be a cavitation problem. NPSHR probably less than 1/10 of that.
I would specify a mechanical seal as 6.5 barg suction pressure could cause excessive leakage from a packed gland.
02/07/2012 12:45 PM
Now, what is the length of the suction line?
And what is the suction pressure (the static head)?
Good Answers: 203
02/06/2012 12:23 PM
As sometimes happens on this type of forum, the question is too broad and not specific enough to give what most contributors would consider to be a good answer. If more data was originally given, such as material being pumped, viscosity, flow rates, pump type, pump capacity, constant or intermittent use, pipe sizes, type of reducer (concentric or eccentric), horizontal or vertical suction, etc. then the contributors could probably give you a useful answer.
As it is now many of the repliers are giving you answers that might be correct in your situation but also might be catastrophically incorrect. They are trying to answer what they think you are asking but their answer can be right to them but wrong for you.
If you want a good answer, post a good and not ambiguous question. An answer can only be as good as the question asked. This is probably why there are so many different and somewhat confusing answers to this posting. In my time it was often referred to as: GIGO, Garbage In= Garbage Out
Good Luck, Old Salt
Good Answers: 102
02/15/2012 12:13 AM
GA.....you forgot to mention the inclusion of photos and/or drawings.
02/08/2012 3:26 AM
according your need..it's not compulsory..
02/13/2012 12:10 PM
Great answer above. Sometimes it requires a lot of information to get to the specific issue.
Register to Reply 45 comments
34point5 (2); CaptMoosie (1); Codemaster (3); gsbasha (1); Hendrik (2); IRSHAD (1); jacksnothere (1); kkgupta (1); lyn (2); Mukesh0861 (3); old salt (2); pnaban (4); pritam (1); Pulpmillguy (1); pushpraj@cr4.com (1); PWSlack (6); sunildas (6); Tornado (4); Wal (1); YesICrane (1); yesyen (1)
