Previous in Forum: What is the Ideal Length of Arc? What is the Effect to Long Arc?   Next in Forum: One Uniform Type of Fuel for the Entire Country
8 comments
Compressor Utilisation & Power Consumption
02/25/2012 12:01 AM
Introduction:-We have following compressor in our factory. This compressor provides compressed air to a) Press shop b) Notching shop c) Auto lath shop. for operating clutch of machine. Due to lack of work load all the departments are not used simultaneously.
Data :- Atlas copco 55KW/ Screw type /Free air delivery 165 litres per scond/ 1000 litres of air accumulator for maximum pressure 7 Bar/ the compressor is set to operate start at 5.6 bar & stop at 6.5 bar./ The compressor shows utiliastion 3138 Hrs of loading & 13300 hrs running. Kindly let me know how to calculate a) Power consumption in running compressor.b) If we use smaller capacity of compressors in individual department separtaely & use them when required in that department.can we save power ?
Regards,
D.N.Shenoy
Pathfinder Tags: Compressor
Re: Compressor utilisation & power consumption
02/25/2012 12:20 AM
Good Answers: 1693
Re: Compressor Utilisation & Power Consumption
02/25/2012 8:54 AM
Yes, you can. The question is the payback period, considering the cost of individual compressors.
With only one compressor, if it fails, you have no air. Multiple compressors would allow one to be taken out of service for repair, and you could still have air.
Popular Science - Weaponology - New Member Canada - Member -
Location: In the sticks of the Central Kootenays, BC, Canada
02/26/2012 1:01 AM
The compressor shows 3100 hours under load and 13300 hours operating, implying that it spent over 10,000 hours idling. Screw compressors usually don't idle very economically--I've seen some screws pull 60% of full load HP when idling, delivering NO air!!
These hours of use are suggesting that your compressor may be oversized for the workload.
Power consumption can be estimated by checking the motor current drawn when under load and when idling. More accurate readings can be done by attaching a wattmeter to the motor and logging the data.
Yes, it seems like you may benifit by going to smaller compressors for each department, sized for the loads seen in each department. Since the loads are quite small, you may want to consider a piston-type compressor with a fairly large air receiver that will allow the compressor to start/stop. Alternatively, consider a piston compressor that can be unloaded while continuing to run, since this kind of compressor, running unloaded, consumes very little power.
You may also want to rent a flowmeter to log the air usage in each department so you can properly size replacement compressors.
Jon.
02/26/2012 1:15 AM
Store gas at a higher pressure in the receiver. Make the compressor load and unload at defined pressures. If the compressor runs unloaded for quite sometime , say 20 minutes , it should shut down and start again when required. Else, increase the capacity of the receiver. you will be able to cut down power requirement.
Power required by reciprocating compressors= PLAN/4500 where p= Pressure, L=stroke length, A=cylinder area, N= RPM.
Also, if the current = I amp, Voltage= V volts, power consumed by motor = 1.732VICosø. This way also, you can calculate the power consumed by motor.
Good Answers: 102
02/26/2012 1:31 AM
Sounds like the system you have may be oversized AND not correctly set for motor cut in pressure.
You can't store at above 7 Bar but you may be able to cut in at a lower pressure.
What is the minimum operating pressure (not delivery pressure) of your various shop tools? Can they operate if the delivery pressure drops down to say 3 or 4 Bar?
That 5.6/6.5 hysterisis seems a little narrow.....
02/26/2012 7:56 AM
You have had some good answers - particularly Sawmilleng.
Just to nit-pick, a 55kw compressor will only produce about 150 L/s at 7bar, but as 55kw is just a number on the nameplate, where motors usually have a 10% over-capacity, then you might be pulling 60kw at peak load.
Therefore use the line current x voltage x power factor to estimate power. Do this for both on-load and off-load. Then x the hours of each, and then x the price per kWhr to arrive at the running cost.
Whatever the cost, the average full load demand is only 25% of the time, a smaller compressor to match this demand would appear to be suitable. But be careful because it might not be big enough (even today) to cope with max demand.
On balance, if your original compressor was designed to match full load demand of full production, then a smaller compressor will not cope when you get busy again.
If the idea of one compressor per workshop is viable, then it might be better instead to replace you existing compressor with thee equal size smaller compressors with load sharing controls arranged with one running continuously on-load, the second on stop-start, and the third off-load (but selected in rotation for wear-and-tear and maintenance).
That would certainly save on running cost today and in future. Whether the capital outlay is viable in today's economic environment is another matter.
02/26/2012 5:01 PM
Back to the beginning. Have you talked with the folks who sold/service these units ?
They do this sort of analysis on a daily basis, and should already have the numbers you seek.
05/28/2012 5:45 AM
Air compressor efficiency is the ratio of energy input to energy output. Many air compressors may be running at efficiencies as low as 10 percent. Improving AC efficiency can yield significant savings to your facility. Thanks.
Register to Reply 8 comments
horace40 (1); IRSHAD (1); lyn (1); MarkhamCornoit (1); Not too Smart (1); sawmilleng (1); SolarEagle (1); Wal (1)
