Previous in Forum: ASME Fabrication Tolerance   Next in Forum: Efficiency Calculation
10 comments
Flanges
02/27/2012 5:41 PM
Dear sir, can I use the reference of din standard dimension instead ASME flanges
Good Answers: 1693
Re: flanges
02/27/2012 5:56 PM
Depends.
What does your contract/agreement/specification say? Are you buying or selling?
Are you curious about mechanical fit, materials compatibility?
What is your motivation?
Re: flanges
02/27/2012 6:13 PM
designing of valves in asme and din standard i want to know where i use common
Good Answers: 61
Re: flanges
02/27/2012 6:02 PM
Munawwar,
Where are you?
Where is your Project?
Does the Project have a BEDD (Basis for Engineering Design Development) document?
If your project does not have a BEDD document then does it have a Piping Design Engineering Specification?
What does the BEDD or Design Spec say about Flanges?
Who are you position, assignment or responsibility wise in the scheme of piping spec development or use?
I am fairly sure you are not a Piping Material Engineer. If you were you would not be asking this question.
If you are a piping designer then you should follow the Piping Material Line Class Specification.
So who are you and what are you trying to do?
Do it once and do it right
Good Answers: 981
Re: flanges
02/27/2012 6:26 PM
Sure you can. You will then be meeting the DIN standard instead of the ASME standard. If you claim to be meeting the ASME standard by following the DIN standard though, that will be fraud. It depends on what your customer demands.
Re: flanges
02/27/2012 6:36 PM
customer wanted design in both standard
than i try to convenience to customer for the same
Good Answers: 34
Re: Flanges
02/28/2012 5:50 AM
Then use the more restrictive parts of both. WP
Re: Flanges
02/28/2012 7:54 AM
WP
MEANS
Re: Flanges
03/10/2012 5:07 PM
"Whitephone".
Shhhhhhhhhhhhhhhhhhhhhh! You'll wake up Stinky Pete.
Good moaning!
Re: Flanges
02/28/2012 11:39 AM
You can check the cross refrences and if you find suitability then you can consider the two separate standards but in that case you have to specify the stardard for the particular piping element giving refrence of the cross standard. Are you still sure your clint will like this type of piping design.
Re: Flanges
02/29/2012 12:19 AM
thanks a lot sir
Register to Reply 10 comments
Crabtree (1); lyn (1); Mukesh0861 (1); MUNAWWAR HUSAIN SHAIKH (4); PennPiper (1); redfred (1); Whitephone (1)
