Previous in Forum: Motor Bike   Next in Forum: What Are Advantages and Disadvantage 2 Pass Flow and 4 Flow Pass Heat Exchanger?
11 comments
Air Chillers for 3rd and 2nd Stages of Air Compressor
02/28/2012 8:15 AM
How reliable are moisture traps on the air chillers? Lets say if we blow them down every day. We also could just blow air though the taps to make sure there is no liquid build up, however that will waist significant amounts of air. My Unit super, is really against moisture traps (I personally don't see any problem with them). Could anyone comment on common arrangements to deal with the problem ?
Re: Air Chillers for 3rd and 2nd Stages of Air Compressor
02/28/2012 11:31 AM
If you can keep personal whimes away, particularly I have found armstrong make moisture seprator traps functions reasonably satisfactorily. Ocasional cleaning and blowing is needed.
Still I have seen many operators uses drain separators with LCV and bypass drain valves as neccesary provisions.
02/28/2012 1:03 PM
Than you for the reply. My concern about moisture traps, is that it is very humid here. I did simple bucket test today, and i got .1 gpm of water out of my chiller. Meaning in 6 gallons of water an hour, seems like a bit of a flow for moisture trap to be handling ?
Good Answers: 67
02/28/2012 11:45 PM
Lot of information like type, discharge pressure, temperature and flow rate of compressor, average RH etc are missing. Why need chilling, is only cooling not sufficient?
Moisture traps are essential in air compressors. In the process of compression moisture condensed after each stage due to interstage cooling need to be removed before entering the air to next stage, otherwise it will have adverse effect on next stage impeller or piston.
Automatic moisture traps are of two types- 1) sensing condensate level and opening and 2) opening with resettable timer. First type is good because of no air loss but reliability is to be ensured frequently. Second type has two timer settings, a) open duration and b) gap between openings. Settings depend on rate of condensate generation which in turn depend on atmospheric RH and pressure rise in stage. For dry inland areas moisture traps are generally not required after first stage.
02/29/2012 7:50 AM
Let me paraphrase, its actually cooling we just always called them "chillers". Usually we try to keep temps below 120F. IT is a 5000 scf/m compressor at least was rated for that flow when it was new. Discharge pressure is roughly 100 psi.
02/29/2012 9:31 AM
Thank you, that helps a bit. I only have one year of experience and I'm chemical engineer, with some mechanical back round. Thought it was a commonly used operations (at least makes sense not to waist the air and run portable compressors).
02/29/2012 9:29 AM
thank you. Yeah I see that a lot too, unfortunately.
Good Answers: 102
02/29/2012 1:16 AM
If you don't dump the condensate then you are reducing your storage capacity by 6GPH or filling up the interstage plumbing at that rate. Could go hydraulic if not manually purged and throw a leg out on the subsequent stage(s).
Ask you super what his hang up is with water traps. It would be good to hear his reasoning. He is your mentor after all. Maybe he has experienced a career changing moment that involved a water trap.
02/29/2012 7:54 AM
Thank yall for helping me out. I'm going to talk to my supper, from what I've gathered he had a lifechanging experience in 70's when he shut down the refinery because of the moisture...But from what I've been told its more than just compressors, air dryers and so on...So I believe that is trying to be over conservative on this matter, but if you upkeep the moisture traps and check them periodically, it should not be a problem at all. And i did check into sensing devices on the moisture traps, however the cost per one with those spikes to almost 7k $. And I do not understand why you need those if operator should check them at least once per shift anyhow.
Good Answers: 67
03/01/2012 12:08 AM
Earlier, I asked for type of compressor also. But with the given information I can presume that it's a 3 stage centrifugal compressor. In fact you should have moisture trap after first coolers also, as you described humid atmosphere. Coolers may also be equipped with moisture separators/ dampers, so that free water droplets shall not be carried away along with air to next stage impeller. Free water particles are very dangerous for high speed impellers (what is third stage rpm?), it causes corrosion, erosion and uneven deposition. It may result in rotor unbalance, reduced life and accelerated fouling of coolers on shell (air) side.
In industries many failures are due to manual interventions, which should be avoided as far as possible otherwise it may be like loosing pounds to save pennies. Auto traps may not be so costlier, discuss with different suppliers for your application.
02/29/2012 10:16 AM
There are automatic moisture drain valves in the market. You need not keep blowing the moisture manually. By the way, moisture that is condensing has to be blown away.
Good Answers: 102
03/01/2012 1:13 AM
If you need to purge manually then it's not automatic.
Fully automatic traps exist. Reputable brand here
Register to Reply 11 comments
IRSHAD (1); Mukesh0861 (1); pritam (2); sayrap1 (5); Wal (2)
