Previous in Forum: Regarding CT Meter Reading   Next in Forum: 400VAC Rated Motor to Run on 380VAC System Voltage
Inter-Connection Of System And Grid Earthing
03/07/2012 10:11 AM
I would like to know why the neutral point of the transformer is not connected to the grid and so that we will have one common earthing in the system for all the transformer neutral and grid electrically connected .
Re: Inter-Connection Of System And Grid Earthing
03/07/2012 11:24 AM
It should be bonded to the internal electrical system grounding. By grid are you referring to the primary distribution system grid?
Good Answers: 181
03/07/2012 10:28 PM
03/14/2012 4:29 AM
I presume that you have mentioned earthing grid to be connected with neutral earthing pits.
Grounding & Earthing is both different concept as grounding is done with live part & Earthing is for human safety non live parts. again it can be said that ultimately both purpose is same. looking on fault point of view & operation of resticted earth fault relay, merging of grid with neutral grounding may not be allowed.
Good Answers: 169
03/20/2012 12:15 PM
Why not? In fact, it MUST be connected to the grid.
abele (1); electricalexpert65 (1); TonyS (1); wareagle (1)
