Previous in Forum: Harmonic Propagation   Next in Forum: Turns Per Coil
How To Find Starting Current For Star Delta
03/28/2012 5:32 PM
A 3-phase 6 pole, 50 Hz induction motor take 60 Amp at full-load speed of 940 rpm and develop atorque of 150 Nm. The starting current at rated voltage is 300 Amp. If star delta started is used, what the starting current? Can you help me?
Re: How to find starting current for star delta
03/28/2012 5:39 PM
Use the forum search...this question has been answered many times...
03/28/2012 5:45 PM
but i can't find it.. please help me.. i have to submit my assignment today...
Good Answers: 181
03/28/2012 9:30 PM
You should have put more effort in to your assignment.
This is NOT a homework cheat site.
Re: How To Find Starting Current For Star Delta
03/28/2012 7:21 PM
Good Answers: 804
03/29/2012 9:15 AM
Truck question.
In REALITY, the starting current peak will be the same or even worse. Only the duration changes.
03/30/2012 9:31 AM
Use a tong meter to measure your starting current of your star delta starter. If you not able to catch the tong meter deflection speed then hook it up with a recorder and record it.
Register to Reply 7 comments
biase2jer (1); JRaef (1); nobodysomebody47 (1); Simon Wan (1); SolarEagle (1); TonyS (1); wareagle (1)
